This is a pretty common break on old milling machine tables. I fitted a chunk of copper bar under the tee slot to save machining later then i stick welded it with some 5/32 Viking Metals machinable cast rod i got cheap off ebay, wrapped it up in some insulation and let it sit a spell. It should clean up nice....Bob
Cast Iron Milling Machine table repair.
Looks good Bob thanks for sharing[email protected] trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
