Hi all, does anybody have any ideas, pics of a plasma cutting table thinking of making a table that I saw on dvd had square raised box about 4" above work table with bars spaced about 4 to 6" apart. Thanks for your ideas, WelderCraig
Hey WelderCraig,
sounds like you could make any design you want. Lots of talk on making welding and cutting tables the past couple months. Your idea sounds fine.
Will you have a bin underneath it or just the cement floor
bert
I made a way to cut a little straighter by taking a sawhorse and welding a hinge to 1 side and on the other side of the hinge I welded a peace of angle so that you could lay the sheet steel down on the sawhorse and fold the angle down on top it clamp the other side witch will hold it in place and put the tip against the angle for a guide
I think it works great and is easy to take with you
