Does anyone have a set of plans for a hydrolic can crusher?
Can Crusher
Can Crusher Plans
Hey tigrig2, if you still need plans here is a link to some plans you can purchase.
http://how-to-plans.com/pop_can_crusher.html"Why go around the mudhole when you can go through it"
Miller Bobcat 250
Miller Syncrowave 200
Lincoln Pro-Core 100
This is one I built some time ago, I used an air cylinder for a dump truck tail gate and the pipe is 3'' exhaust for a car.I also put exhaust regulators on the valve to help save the fingers(you can adjust tem to control the speed of the cylinder).It`s super simple and doesn`t take long to build.Attached Files
THe air one is impresive and the manual one is definatly simple to build just use your imagination after looking at the pic that was posted good luck[email protected] trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
I like that air operated one. So many of them are lever action where you have to put the can in and take it out. Easier to set them in a line on my back sidewalk and just stomp on them. If you could rig up a feeder for the air operated one, that would be the ticket! Load a bunch of them into the hopper and then run through them!Syncrowave 250DX
Millermatic 250X
Hypertherm PowerMax 1100
