is anyone running one of these machines i am now interested in purchasing one for my home shop machine also can you get quality welds from the flux core wire without gas
180millermatic
Originally posted by k.a.m. View Postis anyone running one of these machines i am now interested in purchasing one for my home shop machine also can you get quality welds from the flux core wire without gasRegards, George
Originally posted by hiflyer View PostSundowner,
Since you have the MM140 W/AS, how about some feedback on that unit.. Considering getting one, and passing it along to my son after I have a little fun with it.
ThanksRegards, George
As of now, I can't comment on its performance with flux core, but I have a spool of .035 that I'll be using in the next few days.
The machine is capable of doing much more than I have the skill to tackle.Tom Veatch
Wichita, KS
I used it with .030 and C-25. Nice machine and seem to wet-out nice with a pretty crisp arc. The wire was the small roll Miller sent with the machine, (HB-28) so with different wire it will weld different. Based on what I saw from that little test drive, Miller has a keeper. I liked it a lot. Big step up from the MM-175 and might be the best in class? (Big fat sweet spot) The Lincoln 180c ran that same wire like crap. Good machine also.
The MM 180 does have a real nice crisp arc, pretty good weld puddle wetout , and fairly light spatter with an .030 radnor or HB-28 wire and C-25, especially on 1/8". I really liked this unit alot on 1/8" set up this way. Definitely a nice solid wire unit. Much nicer then the MM 175 that it replaced, especially in the areas of arc starts, and window of operation on the wire speed dial.
I didn't run a lot of fluxcore on the MM 180 when I field tested it. The little I did run, I felt it was a good unit. Personally though, with fluxcore I liked the HH 187 better- same wire.
