Just had an idea to start a project specific thread. On this just post ideas and pictures for various welding tables that you have built or use regularly. This way we can start compiling information for easier research instead of looking for a dozen different threads. Not to sound rude, but if your table is simply a slab of plate with four legs, you might abstain from posting. On the other hand, if you have an idea that you think the rest of us would benefit from, by all means post away, especially with pictures. SSS
Project Specific Thread: Welding tables
Welding Tables
Great idea! I was going to use the Miller project table on this website but I wanted to put some type of threaded rod or screw-type thing on the legs so that the table could always be leveled and could be adjusted to the height of the table saw, BS, drill press, etc.
I've got some nice slab tables. Very handy for many things. But more of my tables are a skeleton design, of various sizes. This allows clamping at many different locations within the framework of many fabrications. Some of these tables are very lightweight, others are made from 5/16x3x4" angle. When I get a job that a current table won't do very well, I build another table. Eventually, it's rare that I don't have a table that does the next job.
I'll have to find some pictures later.
Originally posted by atpav8or View Post...I wanted to put some type of threaded rod or screw-type thing on the legs so that the table could always be leveled and could be adjusted to the height of the table saw, BS, drill press, etc.
For just leveling purposes in fact, you only need the adjustment on one leg.
Originally posted by SkidSteerSteve View PostJust had an idea to start a project specific thread. On this just post ideas and pictures for various welding tables that you have built or use regularly. This way we can start compiling information for easier research instead of looking for a dozen different threads. Not to sound rude, but if your table is simply a slab of plate with four legs, you might abstain from posting. On the other hand, if you have an idea that you think the rest of us would benefit from, by all means post away, especially with pictures. SSSNow that's funny....I don't care who you are
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
Originally posted by MAC702 View PostGreat idea, especially when you drag it to different spots in a shop and no floor is perfect.
For just leveling purposes in fact, you only need the adjustment on one leg.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
Originally posted by monte55 View PostI doubt you can level it with one adjuster unless it's a three legged table, and that would only be on one axis. What about three adjusters and one leg.....maybe that needs more thought
I usually just shoot for level in one axis (on both sides). That guarantees that it doesn't have a bind, which is all that's important for most fabrication.
So, probably just putting the adjustment on each leg is best for meeting any need.
I know what you meant Mac.........I was just being awnryNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
Can't build this one unless you own a foundry. They were going to take it to the scrap yard. Got it for free.TJ
Miller Syncrowave 250
Miller CP 200 w/S21-E & Spoolmatic 3
Miller Bobcat 225
Hobart R-300
"There are two kind of people in this world. Those who can weld and those who can't." Jesse James
My Welding Table Minus Dead Chicken
Here are some pictures of my main welding work table. It is 44 " x 97" x 5/8" thick, sitting on 3 x 3 x 3/8 angle frame being supported on 6-4 x 4 x 3/8 square tubing legs with a bottom shelf as you can see. It took a bobcat to bring this into my shop. My friend and I built this a few years ago. You could park your car on this table and it wouldn't budge. I will describe the pictures in order of their appearance.
The 1st picture shows 1 x 2 C channel bolted to table for railing assembly
2nd picture shows another view of same
3rd picture - notice each leg has a receiver tube for a MIG torch
4th picture - notice CNC Router machine in background that made the last picture I show here (for my neighbor who just lost a loved pet)
5th picture - notice hardy hole (spelling might be wrong) for accessories such as shrinker/stretcher shown.
6th picture- notice to the left of the shrinker/stretcher, the pair of 1 " round
welding to underneath of table surface to bend/straighten metal pickets etc.
7th picture- picture of Memorial Plaque for neighbor who lost pet made with CNC Machine in 4th picture.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
More Pictures of Welding Table Minus Chicken
The previous post would only allow 5 pictures so here is the last two.
The first picture here is bender fork for straightening metal, etc
The next one is- Memorial plaque for neighbor's pet.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
One thing I seen that I thought was cool was a guy at work welded a piece of 2" angle to the side of the table. On the long side of the rectangle work table the angle was welded flush with the top and the "V" of the angle pointing down. It makes working with pipe very nice and easy! I want to add that to my current table.Modern Metalworking L.L.C
Blissfiled, MI
517-605-9481
Miller Dynasty 350 Tig runner
Hobart 3-phase mig
Hypertherm 1000 plasma
Mill
Lathe
Box break
Shear
