My Entertainment Center Table
  • My Entertainment Center Table
    Hello All,
    Here is my first metal working project!!! I used my Miller syncro 200!!! WHat do you think??
    Thanks
    Alex
    I like it, how did you fasten the aluminum shelves?
      I like it. I'm also wondering how you mount the diamoned plate.
        Looks like the floor is carpeted? How do you keep that from getting burned up.......
        Scott
        HMW [Heavy Metal welding]
          garabato25
          nice job on your entertainment center. no more tangle wires. ha
          miller bobcat 250
          wc 115a
          spoolmatic 30a
          centery 250 mic
          2 lincoln 225 stick
          a 1954 hobart portable welder w/ willies jeep engine
            thanks for the replies
            Hey guys,
            thanks for the replies...I cut a slit into the metal backbone a 1/4" thick parallel to the ground and just slide each shely in. I also added a small piece of angle iron below each shelf to help support the weight.
            Cheers.
            Alex
              A-w-s-o-m-e!!! Are you going to make a diamond plate back to hide the wires? Per HMW...did you lay fireproof canvas over the carpet when you welded it together???
              bert
              I'm not late...
              I'm just on Hawaiian Time
