Painting Galvanized metal?
Almost as bad here in Florida, but the weather......let us know how things turn out, I would do your 'stripping' outside, the fumes can rust other steel items in the general area...20' radius....but it is quick to strip Galvanized [Zinc coated] Paul
'case you are wondering, yes, I am using my parents garage....45 years old and can't afford a house on my own$650,000 for an average house here on
Oahu,Hawaii. Parents bought their house for $19,000 in 1961. Now they say it's worth $750,00!! Embarressing for what you get!!!!!
bert
Synergy and Paul...thanks a lot!
I know about the respirator bit, got that covered! Far as the holes in concrete, THANKSDidn't know about that, and that is where I was going to do it!!! Guess my parents would've been p'd if they came back from vacation Sunday and found their garage looking like swiss cheese
Problem: Not only dipping the ends, but where all the pickets go also!
1/2" square pickets welded to 1-1/2 x 3/8 flat bar on both ends AND in the middle....(9/16 holes for the middle one so the pickets can slide through and then welded....)
bert
Also remember, try not to be spilling the Muriatic acid on your concrete, it will eat holes in it, and of course, don't breath the fumes....you can just dip the ends to be welded in a plastic bucket with the acid, then dip in water, then the baking soda/water mix, if you just rinse with water, it will probably start to rust as it dries. Hope this helps, let us know how you do. Paul
Just a reminder when it comes to welding or grinding on galvy metal, use respiratory protection. You dont want that crud in your lungs.
Paul,
THANKS!!! I'll try that first! I'm taking off this Wed through Fri to layout and build the gate. 1st REAL project, so I need time to do it right (measurements, etc.) the FIRST time!!! Real simple looking gate, it'll be embarressing to post pics, so I won't...
Gonna use my MM251, since I sold my ThunderboltXL, and saving for my Dynasty 200 in 2 months...
bert
Bert, don't worry about grinding,it is hard to get all the zinc off sometimes, just put Muriatic acid on and wait for it to stop bubbling, it may take a couple of applications, then rinse with water, and put a final rinse of 1lb baking soda to one gallon of water on to neutralize, I have had bare steel outside for over 6 months after this with no rust. Hope this helps,Paul
Oh, btw, I'm going to grind the galv off in the places that I'm going to weld, then spray or brush it with zrc. That stuff works great for a zinc primer...
Thanks guys!!!
I think they are all great ideas, and will have scrap left.
Sooo....I'm going to try each of the techniques, and see which one will last the longest!!! Pretty rainy where I live and where the gate will be. I will keep a progress report
bert
Galva-wash is Product of Sinclair Paints. I could not find a ready link to them, but have found references to their product being specified by the state of California. Hope this will help, Paul
Muriatic acid will strip the galvanizing off, Ospho, which is phosphoric acid can be used to etch the zinc to get the paint to stick, it is also a 'rust reformer' changing ferric oxide 'rust' to phosphoric oxide, which is stable and can be painted with out worry about latter rusting. Do make sure you use a high zinc solids primer [above 90%] as stated earlier. Hope this helps, Paul
Painting galvanize...
Hey Bert,
Painting galvanize takes some thoughtful prep.. You must get the surface to a "scored" condition....a flap wheel in 40 grit would do nicely. Then a good surface wipe with acetone or toluene to get it chemically clean. dabar39 is quite correct regarding zinc. You must use a zinc-rich primer to get a good paint bond. It's the only way. Another thing that helps is after the metal is thoroughly cleaned, warm it to evaporate any moisture. Hope that helps a bit....Good Luck....Denny
You should use a self etching primer or a primer containing some form of zinc
I have seen vinegar or acetic acid used several times. No idea how or strength or anything like that. When I smell it, I run. Vinegar will give me a tremendous headache withing minutes of smelling it.
Hi guys, new to welding....SO many questions, so little time...So I read the forum as time allows...Anyway, my first project is this small gate, using galvanized metal. I''ve seen truck racks painted, then 2 months later, paint starts peeling off. Someone told me there is something called galvawash that etches it for painting. Local paint store never heard of it, neither Home Depot. Paint Store has a primer from Zinsser for $26/gal. Can't I use muratic acid or something?
thanks for all the help
bertTags: None
