Painting Galvanized metal?
  • Painting Galvanized metal?
    Hi guys, new to welding....SO many questions, so little time... So I read the forum as time allows...Anyway, my first project is this small gate, using galvanized metal. I''ve seen truck racks painted, then 2 months later, paint starts peeling off. Someone told me there is something called galvawash that etches it for painting. Local paint store never heard of it, neither Home Depot. Paint Store has a primer from Zinsser for $26/gal. Can't I use muratic acid or something?
    thanks for all the help
    bert
    I'm not late...
    I'm just on Hawaiian Time
    I have seen vinegar or acetic acid used several times. No idea how or strength or anything like that. When I smell it, I run. Vinegar will give me a tremendous headache withing minutes of smelling it.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
      You should use a self etching primer or a primer containing some form of zinc
        Painting galvanize...
        Hey Bert,
        Painting galvanize takes some thoughtful prep.. You must get the surface to a "scored" condition....a flap wheel in 40 grit would do nicely. Then a good surface wipe with acetone or toluene to get it chemically clean. dabar39 is quite correct regarding zinc. You must use a zinc-rich primer to get a good paint bond. It's the only way. Another thing that helps is after the metal is thoroughly cleaned, warm it to evaporate any moisture. Hope that helps a bit....Good Luck....Denny
        * Complete welding, machine, & fab shop *
        * Mobile unit *
        * Finally retired *
        ____________________________________________
        * A man's word is his honor..... without honor, there is nothing. *
        * Words are like bullets..... once they leave your muzzle, you cannot get them back. *
        * I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
        * Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
          Muriatic acid will strip the galvanizing off, Ospho, which is phosphoric acid can be used to etch the zinc to get the paint to stick, it is also a 'rust reformer' changing ferric oxide 'rust' to phosphoric oxide, which is stable and can be painted with out worry about latter rusting. Do make sure you use a high zinc solids primer [above 90%] as stated earlier. Hope this helps, Paul
          More Spark Today Pleasesigpic
            Galva-wash is Product of Sinclair Paints. I could not find a ready link to them, but have found references to their product being specified by the state of California. Hope this will help, Paul
              Thanks guys!!!
              I think they are all great ideas, and will have scrap left.
              Sooo....I'm going to try each of the techniques, and see which one will last the longest!!! Pretty rainy where I live and where the gate will be. I will keep a progress report
              bert
              I'm not late...
                Oh, btw, I'm going to grind the galv off in the places that I'm going to weld, then spray or brush it with zrc. That stuff works great for a zinc primer...
                I'm not late...
                  Bert, don't worry about grinding,it is hard to get all the zinc off sometimes, just put Muriatic acid on and wait for it to stop bubbling, it may take a couple of applications, then rinse with water, and put a final rinse of 1lb baking soda to one gallon of water on to neutralize, I have had bare steel outside for over 6 months after this with no rust. Hope this helps,Paul
                    Paul,
                    THANKS !!! I'll try that first! I'm taking off this Wed through Fri to layout and build the gate. 1st REAL project, so I need time to do it right (measurements, etc.) the FIRST time!!! Real simple looking gate, it'll be embarressing to post pics, so I won't... Gonna use my MM251, since I sold my ThunderboltXL, and saving for my Dynasty 200 in 2 months...
                    bert
                    I'm not late...
                      Just a reminder when it comes to welding or grinding on galvy metal, use respiratory protection. You dont want that crud in your lungs.
                        Also remember, try not to be spilling the Muriatic acid on your concrete, it will eat holes in it, and of course, don't breath the fumes....you can just dip the ends to be welded in a plastic bucket with the acid, then dip in water, then the baking soda/water mix, if you just rinse with water, it will probably start to rust as it dries. Hope this helps, let us know how you do. Paul
                          Synergy and Paul...thanks a lot!
                          I know about the respirator bit, got that covered! Far as the holes in concrete, THANKS Didn't know about that, and that is where I was going to do it!!! Guess my parents would've been p'd if they came back from vacation Sunday and found their garage looking like swiss cheese
                          Problem: Not only dipping the ends, but where all the pickets go also!
                          1/2" square pickets welded to 1-1/2 x 3/8 flat bar on both ends AND in the middle....(9/16 holes for the middle one so the pickets can slide through and then welded....)
                          bert
                          I'm not late...
                            'case you are wondering, yes, I am using my parents garage....45 years old and can't afford a house on my own $650,000 for an average house here on
                            Oahu,Hawaii. Parents bought their house for $19,000 in 1961. Now they say it's worth $750,00!! Embarressing for what you get!!!!!
                            bert
                            I'm not late...
                              Almost as bad here in Florida, but the weather......let us know how things turn out, I would do your 'stripping' outside, the fumes can rust other steel items in the general area...20' radius....but it is quick to strip Galvanized [Zinc coated] Paul
