Any one have any good advice on o/a torch welding aluminum? I have never done this just wanting to give it a shot. what filler should I use do you have to use any sort of flux? Like I said I have no clue I am used to working with steel.
O/A welding aluminum
Tags: None
Good general purpose aluminum rod....
Hey Iron Man,
There is a very good general purpose rod for aluminum welding that can be obtained on E-bay. Go to the welding section, then to the welding supplies category, then to rods & wire and you will find listings for several suppliers of this rod. I get mine from the gent in Texas. It works excellent and without any kind of flux. The only requirement I maintain is to clean the aluminum with a SS wire brush and acetone to get the welded area chemically clean. Much better welds that way. The other nice option is that this rod will repair die-cast items....you know that garbage type cast metal used for a lot of cheaper castings. Again, even with die-cast, prep the weld area. Normally I MIG weld all my aluminum, but, at times, this rod works well for a quicky repair. In addition, you can use propane, MAPP, propane/oxy., and oxy-acet. to get nice welds. The welding technique is very similar to soldering as you only have to get the alum. heated to the melting point of the rod, and just add it like you would solder to a joint. Hope that helps a bit....Denny* Complete welding, machine, & fab shop *
* Mobile unit *
* Finally retired *
____________________________________________
* A man's word is his honor..... without honor, there is nothing. *
* Words are like bullets..... once they leave your muzzle, you cannot get them back. *
* I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
* Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
What Denny has described is NOT welding of aluminum in the slightest. He is referring to those 3 in 1 flea market rods that are mostly zinc. Stay away from them for any real work.
OA Filler material is the same as used for tig welding as follows
5356 on 6xxx and 5xxx series alloys
1100 on 1xxx and 3xxx series alloys
4043 on castings
Flux, I would try Esab allstate brazealloy #35 or flux from Kent White at www.tinmantech.com
That site also has a lot of good information for the beginner.
Hope this helps as a start, I weld a LOT of aluminum with the torch.
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
