Generator output....
Hey Kevin,
Yes, your generator has sufficient output to run your welder. If you are only welding .250", you won't be using the total input current your welder would use at max, and even if you were running at max, you have enough current output from your gen.. Go for it.....Denny
Generators for the MM251
