Railing help!
  • Railing help!
    After fixing the railing at church they now want me to build a whole replacement railing. I was planning on making it out of 1" square tubing with 1 1/2"X3/16"for the top and bottom rail. I'm just worried it will look to plain. What they have now is the twisted square stock wrought iron and looks nice but I don't have a machine to twist material. Is there a supplier to buy such material or would my 1" tubing look good? I see there are a few of you that do this work and could get me in the right direction.
    Thanks, Shane Wyman
    Modern Metalworking
    Modern Metalworking L.L.C
    Blissfiled, MI
    517-605-9481
    Miller Dynasty 350 Tig runner
    Hobart 3-phase mig
    Hypertherm 1000 plasma
    Mill
    Lathe
    Box break
    Shear
    I think this web site will help you as they sell anything you may want in the metal fab world. King.com. Archetectural Metals. They ship right to your door.
    Wheelchair
      King Architectual Metals and Triple S Steel should have it online. If not in a twisted, they should have a 1" hammered that would look good.
      Don
      '06 Trailblazer 302
      '06 12RC feeder
      Super S-32P feeder
      HH210 & DP3035 spool gun
      Esab Multimaster 260
      Esab Heliarc 252 AC/DC
        Our local Home Depot stores are selling twisted pickets and pickets with baskets. King has a lot of stuff but consider shipping cost.
        Nick
        Miller 252 Mig
        Miller Cricket XL
        Millermatic 150 Mig
        Miller Syncrowave 200 Tig
        2-O/A outfits
        Jet Lathe and Mill
        Jet 7x12 horz/vert band saw
        DeWalt Multi Cutter metal saw
        Century 50 Amp Plasma Cutter
        Propane Forge
        60" X 60" router/plasma table
          King Metals
          King has 1/2" x 35 7/16" twisted pickets on sale for $1.90 ea.
          I recently ordered 750# of steel from them and shipping from Baltimore to Fayettville, NC was $150.
          Do the math.
            That's a great deal! Thanks for the info guy's!!!
            Blissfiled, MI
            517-605-9481
            Hobart 3-phase mig
            Mill
            Lathe
            Box break
            Shear
              As long as you're using hot rolled, just grab a couple of adjustable wrenches and start twisting. It's really not so bad!
                depending on how often you plan on building railings. You could build a jig to make your own pickets. But for a $1.50 migth as well order them.
                  dont have a machean do it old school all you need is a A/O torch, a vice and some friends. heat it up to cherry red weld a pice on the top first then stick it in the vice and twist it that what ide do
                  Dylan
                  RED BIRD WELDING
                  "Experience is simply the name we give our mistakes"
                  HH-140
                  Crappy stick welder
                  Victor supper range II
                  Makita grinder
                  more stuff i don't feel like listing.
                    I use a company called decorative iron. decorativeiron.com/DecorativeIron/
                    They ship very quick, I have also used king.
                    You might try asking a large steele dealer in your area if they can get the molded top rail, that gives the railing a nice look rather than using flat bar.
                    I use the molded top rail and 1" sq tubing and 1/2 inch sq for the pickets,
                    then i put a couple of forged picket casting in on each railing to dress it up.
                    It cost alot to ship some of this stuff, so try to buy stuff local.
                    good luck
                      Here is better link for King, they are in Baltimore,Dallas and I think LA. I have used them many times and feel they offer a great resource, Hope this helps, Paul
                      kingmetals.com
                      More Spark Today Pleasesigpic
                        I think he mentioned using square tubing. We've done it at school using 1/2" solid square. Put one end in a vice with 1" pipe over it to keep it straight while twisting (other end was a "Key" we made using extra scrap 1/2" bar that fit snugly around what we were twisting...If you guys know how to twist manually similar to that, PLEASE let me know, that tubing is a lot cheaper!!
                        bert
                        I'm not late...
                        I'm just on Hawaiian Time
                          what kind of steele you use cold roll or hot?
                            thts how ive always done it
                            lincoln 140c
                            with spool gun attachment
                              Use hot roled 1/2" solid...it really ain't hard to twist...put one end in a vice and use a big crescent wrench on the other end and mark it with soapstone and give it two turns (as a starting point) Take it out and look at it and adjust from there....it doesn't get much more crude or simpler than that!!
                              Then if you like what you see then weld two old 1/2" sockets together and use a big ratchet on one end and a third socket welded to the bench or whatever also using the drive end to put the picket in...still crude but not quite as Neanderthal.
                              Miller 30-A Spoolgun
                              Miller WC-115-A
                              Miller Spectrum 300
