where can I find drawing's or print's used for some of these nice trailer's and ideas I've seen.?
plan's
to fined or plans
one place you can go is northerntool.com they have some plans.in there catalog for 20.00 to 40.00 i dont like to buy plans. i would rather make my own. or you can do like i do lay in bed at night and think about it.miller bobcat 250
wc 115a
spoolmatic 30a
centery 250 mic
2 lincoln 225 stick
a 1954 hobart portable welder w/ willies jeep engine
The best plans for trailers are the ones you think up All you need is some steel and a good welder and cut off saw because the trailer you want to bilud should meet your needs not want someone else has. But if you want some plans for trailers just email me and i see want i can do for you on that. Sometimes you just need a starting point to get going.
There are some basic plans at http://www.championtrailers.com/UTIL...AILER_KITS.HTM
They aren't real detailed but have some good instructions on axle location, which is very important to towability of a trailer.Lincoln Tombstone 180 AC
Hobart Handler 120
Millermatic 210
Old Harris O/A setup
Victor SuperRange II on propane
Hypertherm Powermax 380
Ryobi 14" chop saw
Milwaukee Sawzall
A bunch of grinders
A lotta other tools
Check out my website at: Ed Eldridge's Race Page
trailer plans
The best advice I can give about building a trailer is make it your own. Forget about what the other guy has, build what you need. I have built a couple of hundred trailers over the years and I don't think I have made two alike.
Here are a few personal bits of my preference 1. up to 12 foot 2"x3"x3/16" angle frame is o.k. anything over 12' go to box tubing. 2. Use a 50 degree a-frame coupler whenever possible with tongue cut at 81" and set back 32" into trailer frame should give you about 46-48" tongue length. 3. set your axle at a 60/40 rearward split on single or tandem axle. 4. recess your tongue jack back about a foot, don't use hole in coupler as you won't be able to open a tailgate. 5. whenever possible use a 14 or 15" rim and tire for a number of reasons including stability, weight bearing ability, the bigger the tire the less it rotates the less it wears on the bearings. Two more things, put your lights in an area that you won't run into them walking around the trailer and also someplace they won't be broken off easilywhen backing up, I mount most of mine on the fender mounts. And the other thing is don't weld the fenders on the trailer cause it's not if you bang them into something it's when you bang it into something you'll be glad they are bolted on for easy replacement.
Hope this will help, if you need any other advice or info let me know. I could send you some photos if you need them for example or ideas. Dave
Also depending on where your'e from I could suggest some suppliers that I useIf necessity is the Mother of Invention, I must be the Father of Desperation!
one more thing
I almost forgot, If you go with a tandem axletrailer check with your local laws as some states require at least one axle have brakes, some require a breakaway kit, and some states don't have a ordinance about it. I won't build a tandem without brakes on it. DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
Dabar39,
thanks for posting more of your trailer pics. Friend of mine has been building custom boat trailers for years (he moved before I started welding) and he used ONLY C-channel. While other boat manufactures and people use box tubing, he said it just held the salt water in so the trailer rusted much faster. He built trailers for 16ft - 30ft and all with C-channel. Anything over 3000lbs, he would do a tandem. I think a couple of times he made a triple axle, but that was probably for the 30 footers. His tongue weight was 7-10% of the weight of the trailer and he cut the part where the sides turned into the front instead of bending them. I've seen all kinds...the angle iron like you said will probably be my first project though...I'd appreciate a copy of those plans also if you don't mind
bertI'm not late...
I'm just on Hawaiian Time
BigEd36,
thanks! I downloaded/printed the homepage, that had the specs AND the catalog!!!
If anyone else has other websites, PLEASE shareI think I have some websites somewhere, when I find them, I'll post 'em
I'm not late...
channel frame
I don't like channel frames for utility trailers as the channel has a lot more flex to it than the box tubing does. The channel is fine for a boat where as the load is distributed evenly over the length of the trailer and height it not an issue. Building with channel you would have to build with 6" channel compared to 3 or 4" inch tubing, which in turn raises your trailer deck higher from the ground. I like to keep the deck about 18 to 21" from the ground, with channel you would be a few inches taller and believe it or not those few inches make a big difference in the way it tows, makes it easier to load, and also if you have to climb up and down off it all day long you would appreciate the lower deck height. Also box tubing is a lot simpler to work with in my opinion, I guess it has to do with personal preference. DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
one more thought. Although building it yourself can be rewarding, and probably do a better job, sometimes its cheaper to buy one already built. Some of the big companys pay way less for steel than we do, so sometimes they can sell it for what it would cost you in steel not to mention your time. I built a dump trailer, tandem axle, for myself [for wife actually]. By the time I was done I had spent 2/3rds the cost of a new one on steel not to mention gas, filler metal, time etc. My wife has a landscaping business and is getting ready to need another trailer. I'm really wrestling with buying or building! just make sure you make an itemized materials list before you start. That might help you make up or mind. Unless, of course you just want to do it because we love to make stuff.Scott
HMW [Heavy Metal welding]
i've seen some of the tandam axle trailers that come from the states with only one set of brakes ,, up here in canada its the law to have barakes on both axles for tamdem,, in my opinion it makes sense because usualy if you have tandam in most cases you are going to be hauling waight and should have brakes on both axles.Jorgensen MFG.
Custom trailers:from utility to semi trailers i make em all.
[email protected]
www.ehhitch.com
trailer brakes
You would be suprised at how many customers try to get me to build them trailers without brakes. Why? I have no idea, I have done repairs on dozens of trailers that were equipped with brakes but not hooked up. It makes no sense to me but what do I know, I just build them for a living. Nobody ever listens to the smart guy! Have you ever tried to stop in an emergency situation and barely made it, now try that with an extra couple thousand pounds strapped to your butt (with out brakes). IT WILL MAKE A BELIEVER OUT OF YOU. DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
over the last year i've figured out how to build trailers with channel so it doesent flex,, it is fairly easy and cheap,, no notching or anything and it only requires channel and angleiron,, and one peice of tube for the toung. But as long as you build it properly channel is strong and cheap.... about the brakes.. lol.. dabar have you ever seen a tri-axle without brakes?.. this guy brought a trailer to me for a new deck and all his 12" backing plates (6 in total) where missing magnets and shoes it was pretty much just a bare backing plate.. i made him buy new drums and brakes before it left my shop tho.. i diddent want to be responsible for letting that go on the road.
Jorgensen MFG.
[email protected]
www.ehhitch.com
bmxin: channel trailers
Don't get me wrong, I do build some of my equipment trailers with channel. I was refering to lite duty utility trailers. I know all trailers will have some amount of flex to them. The box tubing around here is about the same price as channel and I just prefer to work with it. As for the single arm tongue, I am not a big fan of those. If every one knew how to properly load a trailer I might say o.k. but I see so many trailers going down the road with the load all the way forward and the back bumper just about dragging down the road. I have changed a number of single arm tongues to a-frames after they have been bent by to much tongue weight. I try to idiot proof my trailers the best I can as 20 yrs. ago only professional people used them, now today every idiot owns one. I have seen some really stupid stuff here lately. Just the other day going down the interstate I saw a guy (thankfully pulled over by a d.o.t. officer) using a Ford Bronco II to tow a car trailer with a Ford f-550 4 door dump bed. the front of truck was tied down to trailer and rear wheels on the road and just this morning I passed a Dodge Dakota pulling a tandem dually trailer (at least a 20,000 lb'er) with a back hoe on it with six Mexicans sitting on the trailer. It just amazes me how ignorant some people really are in this area . DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
