I'm an amateur welder with a 115V Mig, welding up a metal railing out of square tube. I noticed that in the overhead position the sound was intermittently that nice 'frying pan' spatter sound and that I got a ball of molten metal at the end of the wire. Other positions worked just fine.
Tube is .0925 steel; wire is.023 steel. My mig does not have real wire speeds and amperages - but the settings were correct according to the chart.
After awhile it occurred to me that the Argon/CO2 mix is probably heavier than air and so maybe I was losing some of the shielding. Do I have that right? If so do you turn the gas up or use a different welding process?
Thanks for the help.
