Sorry for all the newbie questions about aluminum
. I have to weld this 1/2-inch, half coupling into my aluminum gas tank this morning. Just a little nervous about screwing up the threads. No real big deal I guess, because I could always run a 1/2-inch pipe tap back down through it
. But is there a trick to saving the threads the first time without playing catch up later? I know it would be a bad idea to use some type of lubricant on the threads, because it could leak out and contaminate the weld. What about using Teflon tape, is that a bad idea? Or does one just pray to the welding Gods?
I welded the 2-inch pipe nipple in yesterday with no problems; I only had a 2-inch steel coupling to screw over the threads to keep the nipple from warping, not being familiar with aluminum I figured the threads would gall, but they didn’t!
So I was just wondering if you aluminum experts had any tricks to pass along to an old newbie?
