When welding 4130 thin wall .058 to .085 the welds look good but it has a dark color to it. I even removed the coating on the tube and cleaned it with acetone before welding.
dark welds
corn, from the looks of the pic, it is a shielding gas problem. Could be anything from too little/too much argon flow, to wrong cup size, to bad gas lens (if you use one, look for weld spatter on the screen)...even welding too slow/hot will cause this look from heat build up. Also if there is a leak in your torch head or supplying argon lines, you could be sucking Oxygen into your flow path. Common problem with many causes. Check everything out...or it just could be you're holding your tongue on the wrong side of your mouthMerry Christmas, bOb
Originally posted by FABMAN View Posthey everyone, is it just me, or should the pipe fit-up have more of a fish mouth to it ??
Originally posted by Pile BuckFabman whenever I work on my own, not going by a set of drawings, say like on hand rail. I would only shoot for a heavy 1/3 the outside diameter of the pipe. OSHA only requires handrail to be able to withstand a 200-pound impact if memory serves. But whenever doing anything really structural I would shoot for 1/2 the outside diameter of the pipe. But here is how the book says to do it.Syncrowave® 200
Lincoln AC/DC 225/125
Lincoln Weld Pak 100 wire feed
Looks Hot..
Looks to me like overheating the metal. What type joint fit-up? You should try to keep it to a .010 max gap. I know this is tough, but fit-up is one of the biggest factors when welding 4130. What filler/size? sealed pipe? Back purge? It is always difficult to get a straight answer on any 4130 question.Hope this helps. Later Shane Performance Welding & Machine
Originally posted by Pile BuckOSHA only requires handrail to be able to withstand a 200-pound impact if memory serves.Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
Originally posted by Engloid View PostLooks a bit hot to me. It should hold up fine though.
Although others will disagree with me, I will NEVER reccomend using 1/16" tungsten, unless you're welding under a microscope or something like that.
I agree I think it's to HOT a friend of mine loves to run it super hot. I am still learning but seems like when i have it running a Gold or Silver color the heat is just right but I'm no expert. Engloid is the expert.
Chris
