Where to purchase an Ellis 1800
  • Where to purchase an Ellis 1800
    I've just about finished saving my pennies for an Ellis saw. Not it's time to start looking for someplace to buy it from. 1800 is the model I've picked out (thanks to all the feedback here).
    I haven't really looked much yet. There are a couple of ebay sellers in the $3295 range with free shipping. I'd like to the LWS route if I can find a good price.
    Millermatic 35
    Miller TB302G
    Ellis 1800
    Smith & Victor Torches
    Optrel Satellite
    Arcair K4000
    Ingersoll-Rand 175CFM Diesel Air Compressor
    Home Made Welding Trailer
    Try contacting Ellis directly....
    HTH
    Syncrowave 180 SD
    MM185 with 3035 Spool gun
    1971 Roughneck 1e
    Stars-n-Stripes BWE
    Optrel Satellite OSE
    ESAB 875 Plasma Torch
    Lincoln 200SA Diesel
    O/A Set
    Century 250A/C-D/C BuzzBox
    1.5 kVA Spot Welder
    Phoenix Electrode Conditioning Oven
    My own shop since 1981
    Cya Frank
      Gary, post pics of your project when you build the roller system.
        I bought my Ellis 1600 from Direct Tools out of Glendale Ca.
        Great service fair price and it arrived less than a week.
        Hope this helps
          Hope this helps
          ...and on sale there now at $2,895. A guy can't afford not to buy at that price.
          JD
            Where Are you !!!
            Garybdavis Where are you located??
            Dynasty 200DX With TEC Superflex 9 & 17 Torches,
            Hypertherm 30A Plasma
            Rincoln SP130T Mig
              That is gonna be a sweet setup with the rollers and the saw! Let me know were you find a good price.
              Tobin
              MM251
              Miller Dialarc HF-P 310 Amp Tig
              Victor O/A Setup
              Lincolin 225Amp Buzzbox
              Cummins Freak
                You may want to buy the air kit for it too. Im thinking about
                buying one for my 1800 too. Im told its $200.
                  I bought an 1800 about 2 yrs. ago, and my lws had as good of a price as any of the internet sellers, and had the saw the next day. I try to buy local if I can, and the lws usually gives me a good price.
                    Has anyone used the cool air kit? Does it make any difference?
                      Central Texas
                      Millermatic 35
                      Miller TB302G
                      Ellis 1800
                      Optrel Satellite
                      Arcair K4000
                        Yeah im wondering too.
                          I use a version, shop built, of the air kit. It doesn't offer the selenoid, but a cheap brass valve can handle that all day without problem. I wouldn't really call this a cool air kit...as in a cool gun system used on some machine tools. It is more just for the added removal of previously cut metal chips that the wire brush may not have flushed from the blade gullets. I"m certain that there is some cooling action taking place, but most of the benefit from the adaption is from the higher swarf removal rate. Even with the purchase of a selenoid, I would think it would be far cheaper than spending the added $200 somebody quoted for this accessory.
                          Miller DialArc 250
                          Lincoln PrecisionTig 275
                          Hypertherm 900 plasma cutter
                          Jet 14 X 40 lathe...ditto
                          Logan 7" shaper
                          Ellis 3000 band saw
                          Lots of dust bunnies
                            Yes air helps
                            I added air to my JET and it cools the blade perfectly. I have extended the life of my blade and roler guides, etc. No clean-up. The blade lasts alot longer. I cut alot of stainless steel .
                              What about the mist coolers? I have them on both my lathe and mill. You can set the mist so that it doesn't leave hardly any residue or moisture. In fact, you can cut the coolant off completely so you just have air. They are common in the machining industry.
                              Millermatic 35
                              Miller TB302G
                              Ellis 1800
                              Optrel Satellite
                              Arcair K4000
