FABMAN
its just a question of geting into a rythem. you can do it as you stated by letting off on the foot controle a moving but after you get good at it you will do it with just adding filler, i kinda whip the torch back onto the old bead as the filler goes in and cools the puddle then bring it back to start the next bead, ite just a kind of flick as you add filler.
it takes time to get good at, a lot of time. there are some tricks to getting a good looking bead when starting like you said by letting off on the amps but in time you will be able to do it without leting off the amps. i'm guessing you are new to it as you have the syncro200 so just find some time and some scrap and put in some seat time. i'm still fairly new to it and when i first started i did the heat dab, cool then start ofver but i think you get a beter weld by keeping it hot and using the filler to cool, its also important to use enough filler to keep the bead raised up, and to fill the crater at the end so you dont get that week spot in the weld.
