this has been coverd befor to some extent but i thought i would bring it up again as i just found another loose conection.
i'm shore you all noticed the ground or work clamp conection was loose when you got it, if not put a wrench on it just incase. but i found last night as i was breaking nine down to do some rearanging that it was also loose at the dins conector end. i'm prety shore i checked it befor so maybee it losend up with use but it was just flopping around inside there. it wasprety melted up when i took it out and reatached it. i cut back another 1" and started with some fresh wire and tightend it up realy good in the vice this time. i might give it another test run to see if that was causing my power isues insted of my feed line. i took a pic but left the camera in the shop so i'll post it later on today but just wanted to get this out there for ya.
give every thing a good tightening when you get it.
i cant understand why they would ship it like that but seems like most all of then came loose not just mine.
