FWIW, Im just a simple home user & occationaly make stuff for my hot rod. What I did for one job that I had a few parts to de-burr was to take my 3" belt sander & turn it upside down, & stick it into my vice. I would not trust it to try to true up a piece, but to de-burr it seemed to work pretty well.
Bob
Ellis Belt Grinder
I agree with Kevin. I'd lean real hard on the Wilton 4200A. I bought mine just about the same time he did and have used the heck out of it. I also got it on sale for around $1234.00 but from ENCO (they say they'll beat any advertised price by 5% or something like that). I pointed out the sales price that MSC had running and got it for that price less 5%. I think the ENCO regular price ($1805) is a tad high for this unit and would wait till it was on sale again. Its a very solid-built machine. I've been primarily using Norton blue 60 grit on it and its just plain mean on a piece of steel...and skin too!Don't get your fingers too close as its just as quick to rip open flesh as it is on grinding steel....don't ask me how I know...
http://www.use-enco.com/CGI/[email protected]&PMAKA
Originally posted by lramberson View PostI can't speak for the Wilton machine, but I can for theEllis.
It has been one of my most used purchases and the belts give a very respectable service life.
I grind alot of edges and have even used it to cope tubing on a banister project and even though it is not desiged for this it handled it well.
This is a pretty powerful machine and walked away from my previous import unit that was given to a friend. (he gets all my hand me downs)
I got my Ellis for a respectable price with it's big Brother the 1600, my most used shop tool...LOL
Originally posted by Powerstrokinit View PostWere did you get your 4200 from? That is what I am looking at. A little more $$ than the woodworking unit that Northern-Tool carries, but more more sturdier looking.
Thanks,
Tobinand will handle just about anything you can throw at it. Check around because they go on sale quite often at MSC and Enco. Good luck.
Guest repliedI can't speak for the Wilton machine, but I can for theEllis.
Thanks,
Tobin
Originally posted by Powerstrokinit View PostKevin-
Thanks for the info. I think I will go with the Wilton as it has a larger belt and will save me some $$$. How easy are the belts to get (can you get them from lowes or Home Depot)? Also, can you sand on the wheel part (rounded part)?
Thanks,
Tobin
I get my belts locally but you can also order them thru Enco, MSC, or other industrial suppliers. I am not certain about the big boxes but it is possible they would carry that size.
You can sand on the rounded part easily. I have the Wilton 4200A and on mine the belt will go vertical or horizontal and the top comes off easily with a threaded handwheel exposing the upper drum. Hope that helps.
Kevin-
Thanks,
Tobin
The Ellis is a nice unit. I don't own one but they have them at my LWS from time to time. If all you need is a 2.5" belt width then it will fit the bill quite nicely. I almost bought one but I ended up with a Wilton 6" X 48" belt machine that also has a 12" disc.
Ellis Belt Grinder
Does anyone have a Ellis belt grinder, or used one? I am thinking about getting one since it looks like the best deal for a good sized belt grinder. I have been looking for a good used belt grinder for a while with no luck. The Burr-King line looks like it is out of my price range. It seems like people rave about the Ellis quality.
Thanks,
TobinTags: None
