Hey guys. I just picked up a Miller Maxtron 450 w/ S22A wire feeder. I am going to run on single phase 240 which means that I will need an 89 A circuit for full power. Don't know how often I will run at full power, but would like the option. Currently I have 200 A service to the house. I would like to add a 100 A sub to the garage to run the welder, etc. I understand that I will not be able to have all the electric appliances in the house and garage on at one time. Currently there is a utility pole 10' from the corner of the garage. It has a box with a meter and a 200 A breaker with slots for more breakers below. I have attached a pic of this box. From the box the wires go underground to around the back of the house into the service panel for the house which has a 200 A main breaker also. The service panel in the basement is bonded. It also appears that the panel on the pole is bonded. The bare ground wire seen in the pic goes to a metal rod in the ground. I was hoping to put a 100A breaker in the box on the utility pole, then run power to a 100 A subpanel in the garage. Hopefully all this is correct. One thing I don't know is if the subpanel in the garage should be bonded or not bonded. If I understand properly, if the sub was coming off the main service panel that was bonded, then the sub should not be bonded, but in this case, I'm not sure. Sorry for the long post, hope it's not too confusing. If so I can attach a diagram.
Thanks
Chris
Thanks
Chris
