I built a home made front axle, and I was wanting some imput on what I did.
I first had 4 riser plates cut on a water jet to get the drop I wanted from my spindle to my long main span that goes underneath the car. Next I cut two 2"x2"x1/4"wall square tubing pieces that were about 2.5" long. Each one was welded in between 2 of the riser plates with a main span of the tubing welded between the bottom of the plates and connecting the 2 sets of riser plates on each side. I MIG welded all 1/4" material at every seam and ended up with about 16" of weld, plus 2 rosetta welds on each side, on the smaller pieces of tubing. Lastly, I had spindle bosses machined from 1.5" x 1.5" solid stock that I hammered into the small tubing pieces and welded in. I will try to attach a picture for you to look at. thank you
PS: I have since corrected the scrub line problem, but the spindle bosses were untouched.
