Kevin + Dan, what are the advantages of the puhs and pause or circular methods over a straight bead? TJ
Mig weld pics
Originally posted by TJsparks View PostKevin + Dan, what are the advantages of the puhs and pause or circular methods over a straight bead? TJDynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
Originally posted by Sundown View PostSince you just want pictures here's a vertical down on 1/4" with .030 wire, it was done using Dan's elliptical motion, well that is as near as I can get to it anyway.I'm still getting used to the travel speed with mig. I tend to want to go a little too slow and this results in a little more metal deposited than is necessary. Hints, comments, and pictures are helpful to me.
Jim
Originally posted by Jim-Tx View PostSundown, I'm new at mig and noticed something in your picture that I want to ask about. Don't take this as a criticism, I'm asking because I see the same thing in some of my welds. It appears that the bead is not "washed in" fulling along the edges. Is this normal with mig? I'm an old stick welder and I know the bead characteristics are different. I just need to know what to look for so that I can improve.I'm still getting used to the travel speed with mig. I tend to want to go a little too slow and this results in a little more metal deposited than is necessary. Hints, comments, and pictures are helpful to me.
Regards, George
1 & 2
Originally posted by DanHere are a couple sample welds, on 1/8" from two different units. Both were ran with pretty much a straight travel. I might have used a very slight side to side motion as i traveled along though.
Since your running a 120V unit, that tend to be border line on 1/8", I am also including a picture of a weld produced using an elliptical motion that might be useful for you to use with your unit on 1/8". With my 230V unit, I normal only use this oscillation for the most part on 1/4", and only ocassional then. However, in the past I 've used it on 1/8" too, running one of these smaller 120V units, which is why I am providing you with a sample.. If i can ever get mine loking like the first two that's where I 'll stay and be happy. Thanks for the pics, Farris
Gone But Never Forgotten!
Originally posted by fyoungI like the looks of # 1 & 2 I'm not much on the looks of the stacked dime welds...may be the stick welder in me. If i can ever get mine loking like the first two that's where I 'll stay and be happy. Thanks for the pics, Farris
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
i just realised the only pics i have of my mig welds are the vise i made....slaps forehead! you can see a closeup of the 3 pass welds on the base of the vise in the link in my sig.
i will have to get some more mig picsThe one that dies with the most tools wins
