Miller 2050 and brass sheet
  • Miller 2050 and brass sheet
    I have a CAM with a miller 2050. I have been experimenting cutting brass sheet, .125 in thickness. I have to anneal the sheets so the do not warp with the cutting. The dross is really bad. Any suggestions as to speed and amps?
    thanks,
    marcos
    what typre of dross?
    When you cut, are you getting a lot of smoke? If not speed up.
    I would start out at max amps and at least 150 ipm with new electrode and nozzle with at least .125 off set above the work piece. If you still get a lot of dross try upping to 175 ipm, if you do not get a clean cut work down on the ipm until you do.
    .125 copper I cut at max amps and 120ipm with the best results.
    Oh yeah..and CDA
    hope it helps.
    sstec
      sstec,
      Thanks, I'll give it a shot. I have a downdradt exhaust and never see much smoke.
      regards,
      marcos
        smoke
        marcos,
        So do I...but when you hit the "sweet" spot of amps/ipm/offset you will get smoke showing top side even with the downdraft, that for the most part gets sucked down if you don't have a lot of openings in the cut sheet.
        Let me know how it works.
        sstec
