Welding rigs -- Details
  • Here it is as a single axle & getting the second axle & extending the fender. Moved the original one as far forward as I could with the side door. Click image for larger version
ID:	515409Click image for larger version
ID:	515410Click image for larger version
ID:	515411Click image for larger version
ID:	515412Click image for larger version
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    • In one of my truck boxes I carry misc. mechanic type tools. In the trailer I have welder, feeder, two 125cu oxy, two 145cu acet, one 125cu 75/25, 25' stinger, 21' work lead, two 46' ext. (I have two 80' ext. that I bring when needed, also 100' torch hose) 50' each of oxy/acet hose, mig hose & 14 pin ext. Grinders, clamps, compressor w/60' hose, cac torch, rods, wire, misc. steel, ext. cords, 4' step ladder, rosebud. I'm sure I forgot something but it works great for what I do. Where I mostly go is wide open so no problems getting in & out. I love the fact that everything is out of the weather & hidden from view.
      I can drop the trailer & use my truck as needed without it being tied up & I don't have the overhead of a dedicated truck. Another plus is it is easy to get in & out of with out climbing up. The other nice thing is in the winter I leave the side door closed & it gets to be about 55* inside while in the teens outside. In the summer with all the doors & vents open it stays about outside temp. The silver color keeps it from baking inside from the sun.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Miller spectrum 875
      RCCS-14
      • More Pics
        JIM
        Owner Operator of JNT Mobile Welding & Repair LLC
        Millermatic 350P Aluma Pro
        Maxstar 150 STL
        Trailblazer 302
        Suitecase 12RC
        Extreme 12VS
        Extreme 8VS
        Spoolmatic 30A
        Miller HF251D-1
        Passport Plus
        Spoolmate 100
        Hypertherm Powermax 45 and 85
        Ingersoll Rand Engine Driven Compressor
        Dake 75 ton H-Frame Press
        JD Squared Model 32 Bender
        Miller Digital Elite
        • Some pics.
          JIM
          Maxstar 150 STL
          Trailblazer 302
          Suitecase 12RC
          Extreme 12VS
          Extreme 8VS
          Spoolmatic 30A
          Miller HF251D-1
          Passport Plus
          Spoolmate 100
          • If I recall correctly, there were several threads started about the same time as this one, those who keep posting up asking for "rig ideas", could simply do a search and find every possibility out there.
            Although it woudn't work for me, an enclosed box truck or trailer, set up properly, can actually give you more useable space than a dedicated truck or open trailer. Depends on your needs and your clientele. Myself, over 25 years, went from a pickup, to a flatbed, to a F350 utility bed, to a class 7/8 diesel rig, and now, mostly due to California air regulations and CHP rules, back down to single rear F350's. Gassers, no more diesels. Being in business, it definitely pays to be flexible.
            Last two posters, nice setups, worth thinking about if it fits your needs.
