I only cut if a limited room situation, It is way too wasteful both in time and material to cut them in half
Who cuts their 36" tig filler down?
I admit, I am accustomed to cutting filler very often.. It's just one of those things. It seems that a long filler is never convenient for what I'm doing. I also hate that long end bouncing and dangling around 3 feet away.. Sometimes it messes w/ my control.
I also ALWAYS snap tungstens in half. I never use a full length tungsten.. This is because I hate long back caps with uncomprimising passion..
Originally posted by Billet BennyI admit, I am accustomed to cutting filler very often.. It's just one of those things. It seems that a long filler is never convenient for what I'm doing. I also hate that long end bouncing and dangling around 3 feet away.. Sometimes it messes w/ my control.
I don't just cut them in half, I also cut them to suitable length for the particular weld and discard what is left over. How many little short pieces do you really want to save.
I prefer short pieces for ease of use and figure you are saving money not wasting it since you can produce a better weld fast and besides filler is cheap if it is not specialize.
Ok here's the real question...
Scott got me ta thinkin.How many weld the little pieces back together? Now thats the question...
Bulldog5 Passport Pluses
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
Star & stripe BWE Digital
2 star & stripe xlix's
REAL TRUCKS RATTLE
CUMMINS BABY
That's how I was taught with gas welding, but I have never done it outside of the classroom (I think it was just to get us used to doing little stuff).
The consumables used in fusing the stub cost more than the stub.
I pitch them when they're too small to comfortably hold; with the exception of 1/8", because I use those for alignment pins. Even with those, I usually just cut down a longer stick into as many pins as I need.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
That's what I did with Qxy/Acetylene, when the rod started getting hot, I'd stick it in the puddle & let it freeze. Then weld the new rod to the end of the old one, then reform the puddle & continue the weld.
Oxy/acetylene will sure teach you how to control the puddle! Learning it first really helped me with all the other processes I've learned.Syncrowave 180 SD
MM185 with 3035 Spool gun
1971 Roughneck 1e
Stars-n-Stripes BWE
Optrel Satellite OSE
ESAB 875 Plasma Torch
Lincoln 200SA Diesel
O/A Set
Century 250A/C-D/C BuzzBox
1.5 kVA Spot Welder
Phoenix Electrode Conditioning Oven
My own shop since 1981
Cya Frank
