Who cuts their 36" tig filler down?
  • Who cuts their 36" tig filler down?
    Just noticed that HTP sells 18" aluminum filler rod, and says everyone cuts their 3'ers as soon as they pick them up.
    I've bent mine to go around corners, but never cut it unless it's getting in the way of being added to the joint.
    Anyone else chop their wire short? It's the first I've seen it even mentioned.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    I often do.. Especially on sizes 3/32" and up.
      The shorter length can be easier to handle, especially for people just starting out in tig.
      Dennis
      Thermal Arc 185-TSW
      Millermatic Challenger 172
      VictorO/A
      Atlas Craftsman 12 by 24 Lathe
      Esab PCM-875
      Wholesale Tool Mill-Drill
        I normally cut mine, my tig & table is setup in a corner and the 36" length seems to bang against everything if I don't.
        Regards, George
          That's a very good reason.
          Dennis
          Thermal Arc 185-TSW
          VictorO/A
          Esab PCM-875
            Hey Fish,
            I have a cutting pliers right on my tig wire rack. I pick up the wire, cut it in half, and then hit the pieces with a Scothbright cloth.
            Bulldog
            5 Passport Pluses
            2 MM 212's
            MM 210
            MM 251 MIA
            MM 350 P w/Python
            w/ tig runner
            Trailblazer 302
            12RC w/meters
            Spectrum 1000
            Spectrum 2050
            2 Black BWEs
            Joker BWE
            Star & stripe BWE Digital
            2 star & stripe xlix's
            REAL TRUCKS RATTLE
            CUMMINS BABY
              i don't cut unless they are hitting something.
                I rarely cut mine down unless I'm in a situation like others have stated. If you do much welding, it can get pretty wastefull.
                  Thanks for the responses guys. I can see where it might be easier with the larger fillers. Like I said, I had just never heard anyone claiming half of weldors did it automatically.
                  I have worn out ****s I leave on my mig machine for cutting steel. It's just so rare to need to "produce" a short piece of filler. I typically have a half used one on hand anyway when I need to get into a tight spot.
                  Syncrowave 250DX
                  Invison 354MP
                  XR Control and 30A
                  Airco MED20 feeder
                  Smith O/A rig
                    I usually cut my 1/16" filler in half because it is less flimsy. I find that the shorter lengths are easier to aim and are more accurate. With larger than 1/16", I find it unnecessary. I agree with [email protected] and Coalsmoke, it does tend to be wasteful to cut in half, and it is easier to store 36" pieces.
                    -SPiNNeR-
                    Hobart 135
                    Oxy-Acet w/ Victor torch
                      Everything I use is cut in halve and it was only recently that I even heard of anyone using a full length filler. Surprised to hear so many other people leave them long.
                        I never understood cutting filler in half, personally. I use everything from .035" to 1/8" and never cut them down unless the situation calls for it.
                          The smallest I use is .045 and that just gets a 90 bent on the cold end before being added to the tube so I don't grab it when I'm going for 1/16".
                          Even the 1/8" (which really sucks to use with a 150A machine btw) was never a problem at full length.
                          Just goes to show how there are so many different techniques and styles out there.
                          Makes me wonder how many flatten their tungsten points for DC?
                          Syncrowave 250DX
                          Invison 354MP
                          XR Control and 30A
                          Airco MED20 feeder
                          Smith O/A rig
                            3/32 I keep to length.. 1/16" even.
                            .045" I defin snip in two or else its floppin all around.
                              Not me.---MMW---
                              MM250
                              Trailblazer 250g
                              22a feeder
                              Lincoln ac/dc 225
                              MM200 black face
                              Lown 1/8x 36" power roller
                              Arco roto-phase model M
                              Vectrax 7x12 band saw
                              Miller spectrum 875
                              30a spoolgun w/wc-24
                              RCCS-14
