drewworm
I don't know the workings of your syncrowave but the lift-arc on my XMT works by touching and maintaining contact momentarily before pulling away. If I get too quick, as in a scratch start, there is a tendency for the tungsten to stick. Is it possible that you have to wait longer after you step on the pedal before pulling away? As for your porosity, is it possible that when you are fighting the lift-arc that you are either twisting your torch or long arcing? Either can start the problem. Also do you know that you can't burn out porosity and that by going over a weld that may have a slight problem will only make it worse. The only way to get rid of porosity in a weld is to grind the whole area out. This can mean having to open up a hole an extra 1/8" into the base metal to make sure you got it all.
