Marty, I use denatured alcohol most of the time, and sometimes laquer thinner. I have no idea what is so attractive about acetone other than "that's what the internet says"...it feels awfull oily to me.
Lacquer Thinner contains two known toxins. Using that product will expose you to benzene which is known to cause cancer and to toluol which is known to cause birth defects or other reproductive harm.
That's if you use it for its intended purpose, thinning of lacquer paints. When used as a welding cleaner, the heat from the arc & the heated metal vaporizes the toxins so they can more readily be absorbed by the lungs.
Alcohol will work, but it's slower & more likely not to dissolve all surface contaminants (oils, grease, dirt, etc.). Acetone is considered the safest of the 'hot solvents'. While it is still moderately toxic, it beats all other choices for TIG precleaning.
thank you barry, the kind of answer i was looking for. thanks.
marty
Miller Synchrowave 250
OTC 300DM with external wire feeder
Miller XLi Dale Sr., fibre metal hoods
Metaltek of Ky. Inc.
Home of the Stephensburg weld
