In need of a small torch
  • In need of a small torch
    MUST BE AIR COOLED
    Anyone have pics ? Recommendations ? Seems like there are not a lot of good sites out there for this. I found this so far
    Arc-Zone.com : Page Not Found - Connectors, Cable, & Adapters MIG Guns, Feeders & Parts Plasma Arc Cutting Plasma Arc Welding Purge Gas Equipment Remote Amperage Controls TIG Torches & Accessories Tungsten Electrodes Tungsten Electrode Grinders Water Coolers, Coolant & Parts Gas Flowmeters, Heaters, Mixers Stick Electrode Holders Shop Tools & Storage Apparel, Helmets & PPE Oxy Fuel Cutting & Welding Ground & Work Clamps TIG Welding Filler Rod Close-Out Products Welding Machines & Upgrades Weld Tables JIG & Fixturing Tools Automation & Positioners
    Air cooled and small ain't happening. You need the power cable big enough to take the heat of the current - that means big torch body to accommodate the hose.
    My wp-20 is probably a third smaller than my wp-17 and the 20 is rated for another hundred amps.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
      wow thats purity small, i don't think you will get much smaller than that . you could use that to fix a gold tooth. wouldn't want to open up for the work clamp though. how many amps do you need it in??
      you might try tig depo they have a 125amp pencil head torch.
      TIG-9P-12B 125 Pencil 1-pc Super Flex Cable $105.00
      thanks for the help
        Thanks, I saw this one was purchased from there
          Generally, a torch's rating is duty-cycle based. A 50-amp torch is good to go 100% of the time at 50 amps. My CK-9 is pretty small (thoguh not as small as the 50) and is a 150-amp rated torch. With the superflex cable, it's a pretty nice package.
          Hank
          ...from the Gadget Garage
          Millermatic 210 w/3035, BWE
          Handler 210 w/DP3035
          TA185TSW
            Hank
            I can't exceed the duty cycle on my CK9 without burning my pinkies, I just today got the covers made for the CK9 & the CK20 so it's time to hookup the cooler and see how CL the CK20 runs.
            Regards, George
              I need one that can handle 125 amps
                Where are you welding that you need a small torch?
                Mike. R
                MM 251/30a/4015 roughneck
                Miller portable spot welder
                Inferno >>> Big Window Elite
                  How much Amperage do you need? Why can't you just get stubby collets and a short back cap for your existing torch?
                  Bruce
                    I was thinking about the weldcraft WP9, switching from the #17. I just do sheet meta,l low amp stuff, and wanted a smaller torch with a flex-head as well. Is that a good choice?. It looks smaller then the 17... at least on paper.
                    David
                      What's wrong with a WP-9? That's pretty much the standard in a small air-cooled torch.
                      - Heath
                        Where's a good place to get the stubby collets? I tried to grind one down once. That did not work!!!
                        Bulldog
                        5 Passport Pluses
                        2 MM 212's
                        MM 210
                        MM 251 MIA
                        MM 350 P w/Python
                        w/ tig runner
                        Trailblazer 302
                        12RC w/meters
                        Spectrum 1000
                        Spectrum 2050
                        2 Black BWEs
                        Joker BWE
                        Star & stripe BWE Digital
                        2 star & stripe xlix's
                        REAL TRUCKS RATTLE
                        CUMMINS BABY
                          Don't know, that's what I am considering, just wondering why no one mentioned it and thought I was making a bad choice.
                          David
                            Yep 9's & 17'S are way different in size the good thing is they use the same powercable so you can just switch the heads back n forth and not have to buy two separate torches
                            Dynasty 200DX With TEC Superflex 9 & 17 Torches,
                            Hypertherm 30A Plasma
                            Rincoln SP130T Mig
                              this might be a silly ?? as i may well be over looking some thing but why not just get a water cooled 160A mini torch and use it for every thing???
                              other than not being able to use the gas saver setups is there any disadvantages to a smaller torch ????
                              i understand you don't have a cooler yet but was wondering for those that do or intend to get one.
                              thanks for the help
