any one have people pc, i need a new ISP
  • any one have people pc, i need a new ISP
    i'm feed up with loosing 2-5 days a month, and getting supper slow conections the other 1/2 of the time. any idea's welcome.
    thanks
    James
    thanks for the help
    thanks
    James
    If you want dial-up try www.mfire.com, I had them for over a year, the price was right, I think $9.95 per month and it was never down during the time I had it.
    Regards, George
      Is cable available where your at? If it is, and you can afford it, it is probably the best thing available. However, I know that cost can be a huge issue.
      SolidWorks Premium
      SolidWorks Simulation Pro
      MM210 w/3035
      TA185TSW
      DG Piranha II
      Sharpie Deluxe
      Stars & Stripes BWE
      Blue Optrel Satellite
        thanks
        James
        I've been with this one for 4 or 5 years now...http://surfbest.net.1dial.com/
        NO problems, & about 12.50 per month. I'll stay with them until DSL becomes available here.
        You could also check here...http://www.choosinganisp.com/
        Syncrowave 180 SD
        MM185 with 3035 Spool gun
        1971 Roughneck 1e
        Stars-n-Stripes BWE
        Optrel Satellite OSE
        ESAB 875 Plasma Torch
        Lincoln 200SA Diesel
        O/A Set
        Century 250A/C-D/C BuzzBox
        1.5 kVA Spot Welder
        Phoenix Electrode Conditioning Oven
        My own shop since 1981
        Cya Frank
          no cable or dsl available here dial up is my only option.
          looks like it might be a moot point today the wants to keep it so she doesn't have to change her e-mails tomorrow you know how they can be, thanks for the info I'll keep it till she gets ticked again.
          thanks for the help
            There is muchh to be said for getting your own domain---then as the ISP's come and go it makes no difference . costs 10-15 a month but a number of hosting companies are available. Then you can change ISP's at will
            and have no problems. I think I am on my 3rd ISP since i got my own domain.
            Or was I used to when on dial up--- keep a couple different dial up accounts hoping that one of them would be working.
            by the way there are highspeed options. --- for $50 to $80 bucks a month you can get a satellite dish, via www.wildblue.com which isn't the best thing since sliced bread but if you are in dial up prison it's a way out.
            Not as nice as DSL or cable, and a little more spendy.
            I spent several years on the Starband dish before DSL showed up at my pad.
            rvannatta
            www.vannattabros.com
            Miller Bobcat 225G
            Miller Big 40 ('79 gasser)<gone>
            Miller 375 Plasma cutter<gone>
            Lincoln Vantage 400
            Lincoln Pro-Cut 80
              Rvannatta
              at some point it would be nice to get a domain and web site, but i think i better read up on how to make it myself or i'll end up spending a bunch of $$$ i just don't have. can you get a domain without a web page??? and how do you go about doing it??
              also isn't a satellite connection receive only???
              thanks for the help
                Fun, If you have MSWord you may have a template for a web page. Also, consider buying a book of taking a class. Website creation is the sort of thing that can easily be done from home. I know that it is not the easiest thing in the world but if you got good at it it would be a great little business for you.
                SolidWorks Premium
                MM210 w/3035
                TA185TSW
                DG Piranha II
                Sharpie Deluxe
                Stars & Stripes BWE
                  The satellites now both Hughes.net and www.wildblue.com are two way, as was Starband. The are slower on the up than the down, (like DSL) but that isn't too bad as we send little and receive a lot.
                  I didn't even have 'fast' dialup when I first got the dish. --- dial up where I live never has/would work faster than about 12k.--- because of the distance. I never expected in my lifetime to see DSL, but QWEST --- our local baby bell carrier -- has adopted a policy of extending DSL lines to the hinterlands by installing roadside virtual telephone exchanges. These 'remote DSLMS" as they are called restart the 17,000 foot distance limitation that you hear of regarding how close to the telephone exchange you have to be.
                  As it turns out the remote DSLM that benefited me was more like 4.5 miles
                  from my home, (my driveway is 2.6 miles long). By engineering specs
                  advertized it should not have worked, but it turns out that because our driveway was so long, when that copper cable was installed it was oversized and it further turns out the distance limitation is all about voltage drop.
                  I also benefited because I am so far out in the bush---there are very few splice joints in the cable---with each split being an excuse for more voltage drop. Anyhow I have DSL working at about 1200k down and 486k up which isn't too shabby. You can see the dish speeds and probably half that,
                  and while that doesn't set the world on fire, it is still 10 times faster than
                  dial up.
                  But this dish service is really genuinely 2 way. --- after Katrina, the wildblue people took a bunch of dishes and generators to New Orleans and set them up as emergency communnications sites.
                  Although Wild Blue doesn't presently work in alaska because the geostationary satellite is too far east to 'see' alaska, there are a lot of Starband subscribers out in the Alaska Bush who live with generators and
                  the starband dish is their only communications with the outside world.
                  as for the domain, you don't need a website to have a domain.
                  You have to get the domain first in any event. The $9.96 per month solution
                  is "www.networksolutions.com" For the $9.96 you get 50 email addresses, a domain, and a 'place' to store a website-- actually what you get is some hard drive space on their server.
                  You can grab your credit card and go to their website and have a domain along with 7 gigs of disk space on which to store a web site in about 30 minutes.
                  having email addresses, or web space or a domain is not to be confused with
                  an ISP account. --- You have to be able to get to the internet to get to your email accounts, or your website if you choose to write one.
                  You do have to choose a domain name that no one else has already chosen.
                  I actually own 2 domains. --- I have one hosted by Yahoo which is my "www.vannattabros.com" account with which you are familar, and where I have my website which I have had for nearly 10 years now, (I started it when I had dialup), which is why the older parts of it have really small pictures).
                  This last winter however, I got a chance to snag a domain in my own name
                  so I registered it also. --- so if you try "www.vannatta.com" you will find that that gets me as well. I haven't gotten around to fully implement it yet,
                  but the email is working and I can receive email for example in my own full name: "[email protected]" will get to me.
                  rvannatta
                  Miller Bobcat 225G
                  Lincoln Vantage 400
                  Lincoln Pro-Cut 80
                    BTW, writing a web site is not rocket science now. If you can type in a word processor such as Microsoft Word or Wordperfect, both I believe offer a "SAVE AS" option to save the file in the "HTML" format. While there are more jazzy ways to make web pages that works. --- then the more complex for a newbie is simply copying the file from your hard drive on to your domain server. this is more compliated that it seems, but once you figure it out,---not a big deal
                    rvannatta
                    Miller Bobcat 225G
                    Lincoln Vantage 400
                    Lincoln Pro-Cut 80
                      isp
                      I used net zero/ juno for years and had really good luck with it. Then I bought a new laptop with wireless built in . we upgraded to DSL its only 14.50 a month here. I was paying 9.95 mo for pokey dialup. Hopefully soon they will get dsl out in the sticks for ya.
                      Dynasty 200DX With TEC Superflex 9 & 17 Torches,
                      Hypertherm 30A Plasma
                      Rincoln SP130T Mig
                        Well the digital divide issue has been a big issue for rural leaders. It is getting so you can barely do business without a decent broadband connection, yet vast rural areas are not served.
                        I just got lucky and happen to be on the served side by a nose.
                        but speaking of laptops. --- If you happen to be be in an area where cell phones work.---I'm not---I have to drive to town to use a cell phone, the cell phone companies, particularly Cingular, are adding high speed data communincations equipment to the cell phone service. Beginning with the 100 largest urban areas and working down to whereever there is cell phone service we are on the verge of seeing a faster than dial up connection available by simply adding a card to your laptop (and paying verizon or Cingular $60 bucks a month.
                        this will be of great benefit to guys whose pickup is also their office.
                        rvannatta
                        Miller Bobcat 225G
                        Lincoln Vantage 400
                        Lincoln Pro-Cut 80
                          thanks guys
                          Rvannatta
                          i kinda like the ideal of a domain, i think i'll start there.
                          being in the sticks has its +'s and -'s but can = a nice option for some.
                          shore would be nice to have watter though.oh well some day i guess, but that will just raise the tax's and at the rate our town is spending we will end up being the highest on the U.S. in no time. maybe i should look into politics first.
                          thanks for the help
                            another option for persistent email address
                            There are email services available that offer numerous email addresses, alias addresses (deletable at anytime), POP3, IMAP, EXCHANGE and other options as well. A good example is www.usa.net They are not an ISP only an email host. I have used them for many years regardless of ISP. Some years ago there services were free, but like everything else good service costs.
                              Both Google and Yahoo offer similar services as does I believe MSN.
                              rvannatta
                              Miller Bobcat 225G
                              Lincoln Vantage 400
                              Lincoln Pro-Cut 80
