hard surfacing
Originally posted by CoalsmokeHAHAAHAHAHA!
Originally posted by RvannattaIT is my observation that if you end up with a bead that looks like an earthworm glued to the bucket.
Originally posted by arcalaskaWhat do you all use for hard surfacing on buckets and blades? Thanks
In looking at the descriptions you find some of the hardfacing for 'abrasion', some balanced for 'impact' and some rated for 'high temperature'.
I touched up a bucket the other day with a tube of 3/16's stuff. I set the amperage off the tube instructions at I think 210 amps and moved along
fairly quickly which produces a fairly wide and flat bead.
IT is my observation that if you end up with a bead that looks like an earthworm glued to the bucket---that those tend to get knocked off
in the high wear areas.
hardsurfacing
We have had the best luck with UTP 711B rod. Goes on like spreading butter & get good wear results.
Stoody rod. If you need the exact rod # I can dig it up for you along with a bit of info on it.
hard surfacing
What do you all use for hard surfacing on buckets and blades? ThanksTags: None
