hard surfacing
  • hard surfacing
    What do you all use for hard surfacing on buckets and blades? Thanks
    http://groups.msn.com/ArcAlaskaWelding
    mm350P,Trailblazer 301g
    Spoolmatic 30A
    R115, XR30A, SP32
    TD cutmaster 38 plaz
    PowCon 300sm w/feeder
    Lincoln Hi-Freq
    '05 Topkick Crew 4x4 Duramax Edge Juice w/Att 12' bed
    Stoody rod. If you need the exact rod # I can dig it up for you along with a bit of info on it.
    hre
      hardsurfacing
      We have had the best luck with UTP 711B rod. Goes on like spreading butter & get good wear results.
      252 Miller Mig
      180 Synchrowave
      R - 45 Milling Machine
      Kingston 1100 Lathe
      Miller 2050 Plasma Cutter
        I have an inventory of various McKay Rods. Some are not quite the 'right thing', but I bought out the inventory of a weldindg supply house which was stuck with an inventory that they used to sell to sawmills for hardfacing before the enviros killed the sawmills.
        In looking at the descriptions you find some of the hardfacing for 'abrasion', some balanced for 'impact' and some rated for 'high temperature'.
        I touched up a bucket the other day with a tube of 3/16's stuff. I set the amperage off the tube instructions at I think 210 amps and moved along
        fairly quickly which produces a fairly wide and flat bead.
        IT is my observation that if you end up with a bead that looks like an earthworm glued to the bucket---that those tend to get knocked off
        in the high wear areas.
        rvannatta
        www.vannattabros.com
        Miller Bobcat 225G
        Miller Big 40 ('79 gasser)<gone>
        Miller 375 Plasma cutter<gone>
        Lincoln Vantage 400
        Lincoln Pro-Cut 80
          Originally posted by Rvannatta
          IT is my observation that if you end up with a bead that looks like an earthworm glued to the bucket.
          HAHAAHAHAHA!
          hre
            Stoody 19 or Lincore 60-0
            Jeff
              Originally posted by Coalsmoke
              HAHAAHAHAHA!
              Yes, it is McKay Hardalloy 58 that I am using.
              rvannatta
              Miller Bobcat 225G
              Lincoln Vantage 400
              Lincoln Pro-Cut 80
                All good recomendations.I too have used McKay and UTP with good success.
