Well basically will any metal work for this ? Any tips, hints, ideas ?
Making a fire pit, need some help
Back when I used to buy tires, wheels, & rims for International Harvester farm tractors My rim suppliers used to all say that rear farm tractor rims were the most frequently asked for "Sample parts" to use for fire pits. Now days they are mostly 16 or 18" wide, some as wide as 27" though, and 38 and even 42 & 46 inches in diameter. Smaller tractors = smaller rims. The demountable rims work best because there's no center dish to cut out. There's farm tractor salvage yards in every state. Demountable truck rims would work fine also and are made from thicker gauge steel so may last longer.Denny
MillerMatic 185
HyperTherm 600
Will-Weld 200A Buzzbox
O/A torch
Originally posted by cruizerI use an old washer drum and put bricks around it, works great!, 100% burn and easy to get rid of the asheshre
Originally posted by tigman47Well basically will any metal work for this ? Any tips, hints, ideas ?
Make sure your airflow is good. Keep the logs off the floor of the pit so air can bet under the logs, maybe a couple of vents in the side below the grate level helps keep the fire burning clean so it doesn't smoke up the patio too bad. A smoldering fire from lack of air is no fun to set around. You may want to make every thing easily removable which will help cleaning the ashes out easier. Some type of spark arrester or way to cover it would be good so you can leave it unattended if needed.
Here is a pic of my fire pit. Its sits on the ground of course. Its a piece of 30" gas pipe and the grill I made out of angle iron and an oven rack.Matt
MM175, Lincoln Ideal arc 250, Miller Legend
A common practice at Burning Man is to make "burn barrels" which are basically comprised of a 55-gallon drum, some legs welded onto the bottom, and various designs cut into the sides that also serve the purpose of providing airflow. They work pretty well at providing heat and containing ashes and coals. I've seen some with a means of increasing airflow through the bottom of the fire, which improves the efficiency of burning fuel, but does little to provide radiant heat as coals are consumed too quickly.- Heath
You cant go wrong with an old washer tub. I have one and it works great. heat comes out from the side of the holes and the smoke goes out the top. The white paint on the tub doesn't burn off either with all the heat. Its also portable, I take it with me on camping trips, everybody loves it.
Originally posted by SS.You cant go wrong with an old washer tub. I have one and it works great. heat comes out from the side of the holes and the smoke goes out the top. The white paint on the tub doesn't burn off either with all the heat. Its also portable, I take it with me on camping trips, everybody loves it.
Here the pics of The Washer Fire Tub...
