Originally posted by Stick rod
Plasma or Air Carbon Arc Gouging
Millermatic 35
Miller TB302G
Ellis 1800
Smith & Victor Torches
Optrel Satellite
Arcair K4000
Ingersoll-Rand 175CFM Diesel Air Compressor
Home Made Welding Trailer
Originally posted by Coalsmokejust size your couplers to the cable you are using. If you are not going to go any larger than 1/0 and 1/0 works fine, then why mess with it? I use the 1/0 - 2/0 tweco connectors.Millermatic 35
Miller TB302G
Ellis 1800
Optrel Satellite
Arcair K4000
Tweco model 4, and Lenco LC-40 seem to be the standard wherever I have been. you can get a whip connector for small cables that fits these.Attached FilesJeff
There is no way I could get along without my K4000. I've had it for about 5 months I think?? I run it off of two Idealarc 250's. There is no going back after using one. I use it almost every day. It saves me huge amounts of time and oxygen and actylene. I got a pretty good deal on mine too. I worked on a forklift for a friend of mine and of course when he asked how much he owed me, I said, "Nothing, but I need to borrow that torch." He said, "I don't use it anymore, you can have it. And you can have all the carbons I have too." He handed me a box of 3/16 and four boxes of 5/16. He told me when I use those up he has plenty more. So I haven't even had to buy any carbons to operate it.
Oh yeah, mine has three holes. Seems like the K4000's have different numbers of holes.Zeb's Welding and Machine
Originally posted by J hallTweco model 4, and Lenco LC-40 seem to be the standard wherever I have been. you can get a whip connector for small cables that fits these.rvannatta
www.vannattabros.com
Miller Bobcat 225G
Miller Big 40 ('79 gasser)<gone>
Miller 375 Plasma cutter<gone>
Lincoln Vantage 400
Lincoln Pro-Cut 80
Originally posted by RvannattaI agree. Just an unsolicited hint though---give them a squirt of WD-40 just before sliding them together-- then the pieces will slip easily. If you try to assemble them dry you will have problems.hre
Originally posted by Coalsmokelearn something new everyday. Mind you, i have never had a problem with dry connectors..rvannatta
Miller Bobcat 225G
Lincoln Vantage 400
Lincoln Pro-Cut 80
What I`ve got is the Tweco cable connector 2-MPC set of male and female.Or the Lenco LC 40 is compatable with those also.For air couplers I use the Milton style appropriate for the hose I`m using.I do have a selection of air hose couplers on the truck so I can adapt to the customers air set-up if need be.
Originally posted by J hallAnother hint... Wrap the end of the cable in shim stock to keep the strands collected under the set screw. Some will remember when the shim stock was included with connectors and stingers.
