Can the Hypertherm 190C/Spectrum 125C (as I understand it, these are the same machine basically) for 1/8" aluminum? I realize that a plasma is something that you want to error on the side of more capacity, not less, but in my case I do not have an air compressor and I'm looking to slide by with one of these self-contained units. Right now I use a cut-off wheel to cut "outside the lines" on my sheet of aluminum, then use my beverly shears to make the final precise cut before welding. I was hoping that a plasma would allow me to make that rough cut a lot quicker than the cut-off wheel. But with this being such a small machine, I didn't know if it might end up just being a break-even deal (for example, if I can only move the torch at 5" per minute or something).
Anyone used one of these machines for this material/thickness?
Thanks,
Jeff
Thanks,
Jeff
