Ceriated or Lanthanated on .063" Aluminum?
  • Ceriated or Lanthanated on .063" Aluminum?
    I started tigging some aluminum this week. I have never tried, but I was having the worst time seeing the puddle and controlling the erractic arc. All pieces had been thoroughly cleaned and prepped too. I was using 1/16" pure tungsten since that is what I had.
    I searched this board and found that many use the ceriated or lanthanated tungsten. Is there a difference between the two? From what I read, I am leaning towards the 2% Lanthanated Tungsten (blue) for my application (.063" 6061 Aluminum). Does this sound correct and would it cure the problems I am having? Any input is greatly appreciated.
    Thanks,
    Mike
    AL TIG Newbie
    Need to know what type machine (Inverter or Transformer) you are using to be able to recomend which tungsten to use. I use 2% lanthanated in my TA185TSW, but Ceriated would work as well I believe.
    Regards, George
      It is a Lincoln Precision TIG 185. Yeah yeah, I know, wrong color, but I bought it before I knew about this forum. It has the built in pulser with it.
      Mike
        Try 3/32 Ceriated sharpen to a point and it will ball on its own. Pure sucks and this will work much better. You can also use it on steel.
          Will it ball too much to cause an erratic arc? I am having a hard time controlling the puddle because of this too.
            No, the ball is much smaller and allows for a more focused arc.
              Do you have experience with the lanthanated or do you know how it compares to ceriated? I just want to learn the differences.
              Thanks!
                Scho,
                I believe you might want to try Zirconiated with your welder, being a transfomer based power supply.
                Pete
                  Scho
                  You can use lanthanated for everything.
                  I prefer zirconiated for aluminum though. It's almost idiot proof. Don't ask how I know.
                    I use Lanthanated exclusively on My Dynasty. But I have not used it on a transformer machine.
                      Ok, next question, is ceriated not used for transformer-powered machines? I am going to pick up some tungsten at the welding shop today.
                        Scho, I use nothing but ceriated electrodes with my 180 sd, it works on aluminum and steel, truely idiot proof, I'm not sure if a different electrode will help your issue with erratic arc tho, I've done lot's of aluminum with pure tungsten with no problems, you may have other issues.
                          I would use the pulser on that machine. it will help with that thin of aluminum. I use only ceriated on my transformer machine. Ceriated can be dipped in the weld and it resists contamination.
                          Ben Fox
                          www.FOXPERFORMANCEENGINES.com
                          Miller Dynasty 300 SD
                          Millermatic 130
                          MillerMatic 252
                          Jet Lathe
                          Jet Mill
                          Rottler SG7 seat and guide machine
                            I wouldn't recommend doing that with any electrode.
                              I have used Ceriated with an older Syncrowave 250 it works great. As I said earlier much better than pure.
