Syncrowave 250 with unstable arc
  • Syncrowave 250 with unstable arc
    My friend has a Syncrowave 250 that's having problems, It has a very unstable arc, the arc seems to go everywhere at the same time, like it has 4 or 5 wandering arcs. This is an older machine (80's?) with a Miller water cooler. Any ideas what the problem could be?
    22 years welding experience
    CWB Certificate
    SMAW-all position Steel Alloy
    GTAW-all position Stainless Steel
    Welder Red Seal Endorsement -Canadian Interprovincial
    Pressure Welding Certification
    Try changing the tungsten first. You didn't mention if the problem was on AC or DC or both.
      We tried all the little things, it is definitely a machine problem. I weld with a Syncrowave 250 at work. I have a couple thousand hours experience with the Syncrowave 250 but we have never had one do this.
      CWB Certificate
        Put known tungsten in it as previously posted before trying to diagnose further.
        Pliers
        Screwdriver
        Hammer
          We tried a new tungsten, even a new torch with a new tungsten. One thing I forgot was that we had to keep the amps down at 25 amps or less, any more it would melt the tungsten. The machine was set on DC with a 1/8" tungsten, and anything higher than 25 amps would melt the tungsten.
          CWB Certificate
            melting the tungsten is a characteristic of wrong polarity. Barring that could be a bad diode leaking ac.
            Dennis
            Thermal Arc 185-TSW
            Millermatic Challenger 172
            VictorO/A
            Atlas Craftsman 12 by 24 Lathe
            Esab PCM-875
            Wholesale Tool Mill-Drill
              It was definitely in DC negative electrode, that was the first thing I checked.
              CWB Certificate
                Does it weld ok in ac mode. If so a bad diode is a definate possibility.
                Dennis
                Thermal Arc 185-TSW
                VictorO/A
                Esab PCM-875
                  I didn't try AC, I will try AC tonight and see if it is the same.
                  CWB Certificate
                    Re
                    I had the same problem with my 350sync it ended up that the points were pitted after I changed them the problem was corrected.
                    PS this was happening on AC mode. "Good luck"
                    "Molten Metal Fusion Technician"
                      I guess you could try lift arc to rule out the HF section. It might be a good idea to call tig support at Miller.
                      Dennis
                      Thermal Arc 185-TSW
                      VictorO/A
                      Esab PCM-875
