I think the issue here is getting a hint of the design pressure that the cylinder might have been made for. Prior to the early 1980's most hydrualic systems were faiarly low pressure affairs (less than 2000 PSI) then the Japanese excavators hit with 3 ot 5000 PSI" systems.
It is kind of important not to use a high pressure pump on a low pressure cylinder. Likewise the hoses for the high pressure systems are different as well.
A failed hydrualic system is not pretty
Anymore, the only pipe I use on hydraulics (aside of steel hydraulic tubing) is schedule 80, with slip-on and welded ends (no threads cut into the pipe). These ends are commercially available, usually machined for o-ring boss type fittings.
