Will it turn the stainless really hard ?
Chop saw to cut stainless ?
I've never tried it, but it makes sense doesn't it. Esp. with the lower Fe content in stainless. I would think that a carbide tipped chop saw might be the way to go, although I had someone tell me once that these saws weren't good for stainless (he couldn't provide a reason or explanation why, so I consider it unfounded).hre
Stainless Chop saw Blades
Yes they do make chop saw blades for Stainless. They usually are Zirconia or the Manufactured grains Norzon, Saitech ETC thew also make the carbide type also. The ones for stainless have more teeth than the ones for mild. Evolution makes 3 different blades for their 14" saws one for steel, one for stainless, and one made for aluminum.Dynasty 200DX With TEC Superflex 9 & 17 Torches,
Hypertherm 30A Plasma
Rincoln SP130T Mig
Chop Saw Blades
I guess I should have Clarified my post Most abrasive 14" chop saws turn 3500 to 3800 rpm. the carbide tipped saws turn around 1100-1500 rpm. You do not want to use a 14" carbide tipped on a Saw made for abrasive blades. many of the carbide blades are only rated to 1800 Max rpm, Put that puppy in a abrasive saw & you may have carbide saw teeth stuck in the walls of your shop. Not a happy feeling them sharp tips flying all over.Dynasty 200DX With TEC Superflex 9 & 17 Torches,
Rincoln SP130T Mig
