Watercooled Maxstar 150
  • Watercooled Maxstar 150
    I have a Maxstar 150, the one without the HF and Pulse. Does miller, or anyone else, sell a watercooled set-up for this torch, and is it any good.
    Thanks
    Usually water coolers are for 200 amps and above. I am not sure what torch comes with the maxstar 150 but if it is the 125 amp torch you could try a larger aircooled torch. I am wondering if the torch is getting too hot to hold or you havn't used the maxstar much but think you need a water cooled? If you want a watercooler I would recommend building one and it will save you something like 300 bucks. Or you can but one, just look for them on millers web site. Hope this helped
      OOpps sorry I misread your post. If I am assuming correctly you currently have the torch that came with the machine and it is an aircooled torch. If you want to buy a watercooled setup you have to get a new watercooled torch
        The Maxstar 150STL comes with a 150A #17 air cooled torch that cannot be modified to run as a water cooled torch. If you need a water cooled torch then I would suggest a #20, its rated for 250A and is very small and a pleasure to use IMO, you will also need a dinse connector that will be flowthru for the gas and transport the water back to the cooler. You will also need a cooler, making one is not hard and can be done nicely for under $200 or less, new ones start about $500 and go up from there.
        Regards, George
          I really don't see any need for a water cooled torch on a Maxstar 150. A 125 amp aircooled wil work perfectly fine on a Little Maxstar 150. I use a 125 amp air cooled on my Maxstar 150 STH, and even when running the unit near maximum output the torch never gets hot in my hand.
            Thanks for the answers.
            I haven't found a need for water cooling yet, but If one could get a water cooled torch that is upward compatible, then why not. They have better handling. On the other hand if it's like the pedal and only works on a Maxstar, then I probably wouldn't recover my costs.
              Torch's are not machine dependent, but the connectors can be. I think the torch Dan was refering to is a #9 torch, its a air cooled version of the #20 and uses the same consumables. I used one (a #9) for my 150STL and my 150STH ... they are just about right for the Maxstar IMO ...
              Regards, George
