Bandsaw not cutting straight
  • #46
    The blade is pretty new , not even 10 cuts on it. And I made all the adjustments, I reread everything. Maybe the blade got dull that fast.
    • #47
      ONE! Bad cut, can ruin a blade!! It's a real PITA when it happens
      If you KNOW all the adjustments are RIGHT (NOT just "close enough") try another blade.
      Syncrowave 180 SD
      MM185 with 3035 Spool gun
      1971 Roughneck 1e
      Stars-n-Stripes BWE
      Optrel Satellite OSE
      ESAB 875 Plasma Torch
      Lincoln 200SA Diesel
      O/A Set
      Century 250A/C-D/C BuzzBox
      1.5 kVA Spot Welder
      Phoenix Electrode Conditioning Oven
      My own shop since 1981
      Cya Frank
      • #48
        a blade that gets worn on 1 side will tend to cut in an arc. I some dulled a fairly new blade. I thought I had missadjusted something. Finally replaced the blade in desparation and the problem was resolved.
        Dennis
        Thermal Arc 185-TSW
        Millermatic Challenger 172
        VictorO/A
        Atlas Craftsman 12 by 24 Lathe
        Esab PCM-875
        Wholesale Tool Mill-Drill
        • #49
          Well I was cutting some sch10 pipe 1.5 od and if I let it cut and leave it takes about 20 minutes so I have to apply force.
          http://img136.imageshack.us/img136/3295/manis0067vu.jpg
          • #50
            In your picture you have the blade deflected by the square.
            You MUST CAREFULLY make all the adjustments that have been suggested.
            You cannot just get it "close enough". If you "force" the blade, you'll dull & or strip teeth off of it. If you'll just do what you've been told, that saw will cut!
            Syncrowave 180 SD
            1971 Roughneck 1e
            Stars-n-Stripes BWE
            O/A Set
            1.5 kVA Spot Welder
            Cya Frank
            • #51
              Make sure that the guide rollers do not touch the teeth of the blade at any time.
              In the photo, make sure the blade of the square is above the teeth of the saw blade and try to get it as flush as possible without aplying preasure. (I think the shadows make it look deflected in the photo )
              Leave the square in the same position its in now and raize the saw blade to the top of the square blade and lower it again, if a gap shows between the blades at any piont it is out of wack. ( there will be a little gap becouse of the tooth offset , just account for that )
              My sincere thanks , Pete.
              Pureox OA
              Westinghouse 300 amp AC stick
              Miller Syncrowave 250
              Hexacon 250 watt solder iron
              • #52
                And the angel.
                Frank everything is set, and it still takes 20 minutes to make one cut if I don't touch it.
                • #53
                  A few people already mentioned backing off on the spring pressure. Have you played with that setting yet?
                  Do you have any aluminum sitting around? If it gets really hot while cutting, then you have a dull blade. If it doesn't get too hot, then you need to back off on the spring pressure so that there's more downforce on the saw.
                  • #54
                    I backed off
