Bandsaw not cutting straight
  • #31
    Originally posted by burninbriar
    The back bearing should adjust in & out. It should bearly touch the blade with no presure. If the new blade wont cut some thing is way out of wack and more than likely tore up the teeth on the first cut.
    The new blade cuts but in order to go through a pipe I would have to apply pressure, its always been like this.
    The got one back bearing to spin without applying pressure but then the other bearing won't spin. So now I adjusted it so if I apply pressure both spin.
    • #32
      Try backing off the spring pressure on what you were calling the "autofeed".
      that saw should cut straight & true unattended (it's not blazing fast, but it'll cut) if you got all the previously mentioned adjustments right!
      Syncrowave 180 SD
      MM185 with 3035 Spool gun
      1971 Roughneck 1e
      Stars-n-Stripes BWE
      Optrel Satellite OSE
      ESAB 875 Plasma Torch
      Lincoln 200SA Diesel
      O/A Set
      Century 250A/C-D/C BuzzBox
      1.5 kVA Spot Welder
      Phoenix Electrode Conditioning Oven
      My own shop since 1981
      Cya Frank
      • #33
        For cutting, that has nothing to do with the back bearings correct ?
        • #34
          If you have the spring too tight, gravity can't feed the blade into the work, & the blade won't have enough down pressure on it to touch the back bearing.
          Syncrowave 180 SD
          1971 Roughneck 1e
          Stars-n-Stripes BWE
          O/A Set
          1.5 kVA Spot Welder
          Cya Frank
          • #35
            if you have to push down, the blade is either dull, too fine or believe it or not, I saw a guy with the same problem, and the blade was in backwards!
            MM-251,30Agun,SD180,TB302,Spectrum625
            • #36
              Yep...That would DEFIANTLY cause a problem!!!
              Syncrowave 180 SD
              1971 Roughneck 1e
              Stars-n-Stripes BWE
              O/A Set
              1.5 kVA Spot Welder
              Cya Frank
              • #37
                Blade is in right, blade is brand new and from mcmastercarr.
                • #38
                  Is it cutting straight when you apply down pressure now?
                  If so did you reduce the spring pressure?
                  How did that work?
                  Syncrowave 180 SD
                  1971 Roughneck 1e
                  Stars-n-Stripes BWE
                  O/A Set
                  1.5 kVA Spot Welder
                  Cya Frank
                  • #39
                    Did you actually check to see if the teeth are heading in the right dirrection ? If it is inside out they will be backwards. Dont assume that becouse its new its headed the right direction , Its quite common to have to turn a new blade inside out to get the teeth headed right. I've seen a few blades installed backwards before.
                    My sincere thanks , Pete.
                    Pureox OA
                    Westinghouse 300 amp AC stick
                    Miller Syncrowave 250
                    Hexacon 250 watt solder iron
                    • #40
                      You might have the problem in the link below. If you have to press down on the saw head and the spring isn't too tight then you have the pivot assembly tightened to much against the plastic bushing on the blade side of the saw. I have a hydraulic cylinder on mine and do not use the spring. It will actually try to cut too fast if the valve is open too much. I have slop in the pivot and if it cuts too fast it will angle the cut like your pictures. I have to set the bleed rate so that it cuts very slow to get a straight cut in square tubing.
                      Without the spring attached and the saw in the horizontal position you can wiggle it back and forth if you have slop in the pivot. When the head is coming down it is running square until the last 1/4" - 1/2" of travel then it moves to the right at least 1/8".
                      http://www.4crawler.com/Machining/in...andsawPivotFix
                      Another site with a different way to fix the slop
                      http://www.frugalmachinist.com/bandsaw.html
                      • #41
                        Yes
                        linngl I actually messed with the bolt that controls the pivot, I actually tighten it then backed off, but I think I crushed the washer to much.
                        • #42
                          Well the problem got worse
                          • #43
                            Then you aren't following the suggestions you've been given!
                            Syncrowave 180 SD
                            1971 Roughneck 1e
                            Stars-n-Stripes BWE
                            O/A Set
                            1.5 kVA Spot Welder
                            Cya Frank
                            • #44
                              Actually I turned the speed down, could this be causing it to be worse ?
                              • #45
                                There are speed charts on the web. If you are running the blade speed too fast, or too slow, it won't cut as good as it should. But neither should cause a crooked cut! If you will check all the adjustments that have been suggested in this thread, & make the needed adjustments, that saw should cut square.
                                It will never have the speed, & durability of a first-class high-dollar saw, but if it's adjusted correctly & has a good blade, it WILL produce good cuts! Of course, one cut with something out of adjustment can kill a blade & then that blades life is over, it'll never cut straight.
                                So, recheck ALL the adjustments, make sure the blade is in good shape (or, if any adjustments have to be redone, replace the blade with another new one) & that saw will produce square cuts for you!
                                HTH
                                Syncrowave 180 SD
                                1971 Roughneck 1e
                                Stars-n-Stripes BWE
                                O/A Set
                                1.5 kVA Spot Welder
                                Cya Frank
