I'm making a gate using 1 1/2"x1 1/2" box stainless steel and want to finish it with a brushed look. The stainless steel box tubing currently has a mill finish on it. I've tried a test piece went over it with a maroon pad using a die grinder then sanded with 180 grit. I not really getting the right look. I can still see the mill finish underneath. It also seems to be too shiny. What am I doing wrong? I want it to look like this. http://home.comcast.net/~cadyridah4/IMG_2703.jpg
Brushed look on stainless steel
You will probably have to use a flap wheel. Check out www.csunitec.com and look under the surface finishers to get the idea. Still going to be alot of work depending on how much you have to finish. Might be easier to buy the S.S. in a brushed finish and blend in your welds to match. I have built some S.S. handrails using brushed finish tube. That mill finish is hard to get out. Good luck
So to get the mill finish off I have to do a lot of sanding with 40 grit and then go over it with a scotch bright pad in one direction? I don't have to go a little finer grit after 40 before going over withe the scotch brite pad?Millermatic 251
Miller Syncrowave 180 sd
Lincoln Pro-Cut 55
Oxy/Acetylene
Originally posted by bvweldMight be easier to buy the S.S. in a brushed finish and blend in your welds to match. Good luckDenny
MillerMatic 185
HyperTherm 600
Will-Weld 200A Buzzbox
O/A torch
Just try a section and see how it looks, I've done a few gas grill
stands and tops and the 40 looked ok. The belts wear out real quick
and I just used the scotchbrite to "soften" up the look a little.
I saw one of the grills after it was outside for about a year and
it still looked good.
I think this is one of those things that you will just have to play
with till you get the "look" you want.
Dave P.
The RoLoc Bristle Discs work well to match a #4 brush finish.
Available in lots of sizes -- I use the one that fits a 4 1/2 inch angle grinder. Only the green disc (coarse) is needed, unless you want a finer finish.
I've heard about people running stainless tubing through a wide belt sander, like those in a commercial woodworking shop. This gives a straight line scratch pattern. Might be worthwhile if you have lots to do.Barry Milton
____________________
HTP Invertig 201
HTP MIG2400
Miller Trailblazer 302, Spoolmatic 30A, Suitcase 12RC
Clarke Hotshot
Originally posted by precisionworksThe RoLoc Bristle Discs work well to match a #4 brush finish.
I've heard about people running stainless tubing through a wide belt sander, like those in a commercial woodworking shop. This gives a straight line scratch pattern. Might be worthwhile if you have lots to do.Millermatic 251
Lincoln Pro-Cut 55
Oxy/Acetylene
It will give swirl marks. I tried that route first, also tried it with a 5 inch hook and loop pad with scotch brites on a grinder. I have a 1x48 belt grinder that has a scotchbrite belt on it. It will get tubing very close. For sheet i think the way to go is with something like this:
I tried using the belt sander with 50 grit paper. Works pretty good but the finish is not as dull as I want it. If I go over it with scotch brite pads will that give me the dull look?
Also, trying to get the mill finish off with the belt sander seems to take long and really eats up the paper. Is there a faster way? I was thinking of using a grinder with a 36-40 grit paper to get the mill finish off and then going over it again with the belt sander with 50 grit. Should that speed things up?Millermatic 251
Lincoln Pro-Cut 55
Oxy/Acetylene
