Need help with wiring garage for 210
  • Need help with wiring garage for 210
    I am planning on using a 30 amp 2 pole breaker with 10/3 wire. The black and red will connect to the breaker, white and ground to the appropriate bus bar.
    The outlet I am using is a Cooper 50-A-250V NEMA 6-50 surface mount outlet. The instructions say the ground connects to green, the white to silver screw, and black and red to the remaining 2 screws. Only thing is I do not see the silver screw. Since I already have the 10/3, should I just not connect the white wire at either end and only use the 2 hots and ground?
    Any help would be greatly appreciated.
    Here are 2 pics. The first is a clear shot of the outlet. The second is a little blurry, but shows the entire box.
    Pic 1
    Pic 2
    ________________
    Greg
    Miller 210
    Diversion 165
    Hang in there pdog, hank will chime in here when he gets the chance and will correct me if I am wrong. It seems to me that you only need to be concerned with the 2 hots and the ground.
    SolidWorks Premium
    SolidWorks Simulation Pro
    MM210 w/3035
    TA185TSW
    DG Piranha II
    Sharpie Deluxe
    Stars & Stripes BWE
    Blue Optrel Satellite
      That is what I was thinking, but I am far from an electrician. My wire hasn't come in yet so I still can't weld but I was hoping to get the electrical end done today so I am ready to roll once it gets here.
      ________________
      Greg
      Miller 210
      Diversion 165
        Run the black and red to the two parallel terminals (red) and the white to the 3rd one (green). At the breaker box the red and black each go to a side of the breaker and the white to the neutral bar.
          No ground?
          ________________
          Greg
          Miller 210
          Diversion 165
            Pic 1
            Pic 2
            The silver screw should be in one of the holes between the screws you have mounted the box with. It's an equipment ground & goes to the base of the box. You have everything else correct.
            HTH
            Syncrowave 180 SD
            MM185 with 3035 Spool gun
            1971 Roughneck 1e
            Stars-n-Stripes BWE
            Optrel Satellite OSE
            ESAB 875 Plasma Torch
            Lincoln 200SA Diesel
            O/A Set
            Century 250A/C-D/C BuzzBox
            1.5 kVA Spot Welder
            Phoenix Electrode Conditioning Oven
            My own shop since 1981
            Cya Frank
              The only place there is another screw is right between the 2 copper screws you can see a hold. That is the long silver screw that secures the cover to the base.
              Couldn't I cap the white wire at each end and run the black and red to hot and connect the ground to the green and ground bus bar?
              ________________
              Greg
              Miller 210
              Diversion 165
                Cope is correct, I was assuming that you had the panel end of it covered already. You don't need a seperate ground because the nuetral is bonded to the ground at the panel.
                SolidWorks Premium
                MM210 w/3035
                TA185TSW
                DG Piranha II
                Sharpie Deluxe
                Stars & Stripes BWE
                  Great. Thanks all
                  ________________
                  Greg
                  Miller 210
                  Diversion 165
                    You don't need a separate ground for it to work, but you will need it if this wiring job has to meet the national electric code. They now want a separate ground & neutral.
                    Syncrowave 180 SD
                    1971 Roughneck 1e
                    Stars-n-Stripes BWE
                    O/A Set
                    1.5 kVA Spot Welder
                    Cya Frank
                      Frank, if the plug is in a box that is connected via conduit to the panel enclosure is a seperate ground needed? I want to be certain that what I have done is correct and that I don't misinform folks. I have had a couple for threads regarding subpanel wiring and one has a diagram of what I installed. Please look at the attachment.
                      SolidWorks Premium
                      MM210 w/3035
                      TA185TSW
                      DG Piranha II
                      Sharpie Deluxe
                      Stars & Stripes BWE
                        I'm not an electrician (but I HAVE stayed at a Holiday Inn ) I have installed a couple of sub-panels for myself in the past year, & the electricians recommended (strongly) that I run 4 conductor cable with separate ground & neutral conductors. They called it an "equipment ground".
                        I personally don't see the need for it, but don't want my insurance to be in jeopardy because I didn't wire something according to the NEC.
                        You probably should check with some local electricians.
                        Syncrowave 180 SD
                        1971 Roughneck 1e
                        Stars-n-Stripes BWE
                        O/A Set
                        1.5 kVA Spot Welder
                        Cya Frank
                          Will do. Thanks for your input Frank.
                          SolidWorks Premium
                          MM210 w/3035
                          TA185TSW
                          DG Piranha II
                          Sharpie Deluxe
                          Stars & Stripes BWE
                            If I'm reading the NEC correctly; on a 220V circuit, you don't need to carry a neutral. The two hots go to each side screw on his outlet and the ground goes to the green. Three conductors should be all he needs (black = hot, red = hot, green = ground)
                            MM210 w/3035 Spooler
                            Stars & Stripes BWE signed by Andy
                            TA185TSW w/Miller Radiator 1
                            Miller Spectrum 125C
                            Parker Plasma 40
                              The 6-50 plug recepticle configuration only allows 3 wires also.
                              SolidWorks Premium
                              MM210 w/3035
                              TA185TSW
                              DG Piranha II
                              Sharpie Deluxe
                              Stars & Stripes BWE
