My old Miller BlueStar 2e had the same gas tank and muffler set up. There was a thin metal heat shield between the two, but the tank still got pretty hot. My TB302G is bit more safe.
Welding Rig Pictures
Originally posted by J hallWeldinman,
I also have a '89 model Airpak. How many time have you had to work on the compressor head?
Jeff
later
mike
My take is that if you are having to regularly refuel your welding machine in the middle of the work day you are using the wrong class of machine.
On machines intended to work hard all day, regularly, the manufacturers put a fuel tank on that will run the machine for a shift and many times a lot more than one.
JTMcC.Some days you eat the bear. And some days the bear eats you.
Originally posted by JTMcCMy take is that if you are having to regularly refuel your welding machine in the middle of the work day you are using the wrong class of machine.
JTMcC.rvannatta
www.vannattabros.com
Miller Bobcat 225G
Miller Big 40 ('79 gasser)<gone>
Miller 375 Plasma cutter<gone>
Lincoln Vantage 400
Lincoln Pro-Cut 80
It's too bad we all couldn't get what we want. Some of us had to use what we were told to use, some of us had to use whatever we could get our hands on.
Found these pictures posted by "Buddy" on the other message board Sunday:
Brings back the memories (not all good).
Generally would go about 2 - 3 hours between fillups. Not all of us were born with an SA200, we had to make do with what we had.
Originally posted by RvannattaThey do now. That has not always been the case.
It's been the case since the late 1950's.
Anything that has to be refueled during the day, regularly, isn't the proper machine for regular all day use.
Originally posted by RvannattaThey do now. That has not always been the case. OUr Vantage 400 has a 15 gallon tank, and the fuel guage hits empty when it is 12 gallons down. In our usage, it seems to burn about .75 gallons per hour. This implies it will run all day even if you work a double shift.hre
Originally posted by Coalsmokethat's pretty good considering the size of the machine.
The big advantage of a diesel engine is it tends to use only the fuel necessary to do the work required. My trailblazers would all use close to or over one gallon/hour turned to maximum, and the Hobart (four cylinder Ford industrial engine) would use close to 2 gallons/hour (~20 gallon tank).
Originally posted by admweldPortable welder is back but i was hoping there would be photos of his truck but now i,m wondering is there even one he said he would post photos well where are they?hre
Originally posted by garybdavisThanks for putting up with the questions. I'd love some close up pictures.
I purposely bolted down the cable rack I put on my welding trailer because I wanted to make a set of reels for it, but hadn't finished researching it. I knew I didn't want cable reels with electrical connections because of the maintenance issue. I also wanted the electric, act/oxy, and welding reels to be the same size. Yours are the closest I've found to what I'm going to do.
garybdavis,
I finally got some pictures of my spools. If you're still interested then send me an email and I'll send them to you. My email address is: [email protected]
JTMcCSome days you eat the bear. And some days the bear eats you.
JTMcC
Post em up....Syncrowave 180 SD
MM185 with 3035 Spool gun
1971 Roughneck 1e
Stars-n-Stripes BWE
Optrel Satellite OSE
ESAB 875 Plasma Torch
Lincoln 200SA Diesel
O/A Set
Century 250A/C-D/C BuzzBox
1.5 kVA Spot Welder
Phoenix Electrode Conditioning Oven
My own shop since 1981
Cya Frank
realy, like we done hung in here for 16 pages waitin on your pic's lets have em.thanks for the help
[email protected]
