rvannatta www.vannattabros.com
Miller Bobcat 225G
Miller Big 40 ('79 gasser)<gone>
Miller 375 Plasma cutter<gone>
Lincoln Vantage 400
Lincoln Pro-Cut 80
sorry about the file guys,the pic was to big for the forum.so i had to resize it with adobe,and i dont know how to change it back to a jpeg now.
if you are using microsoft wind.XP you can go to the microsoft site and then go to power toys and download a picture resizer for free, its a great lil program that is simple and fast, you dont even need to open the pic to resize it. it downloades real fast even on dial up (like mine )
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
for photoshop: open file, save for web, then on right hand side of screen use the resize function, resize, make sure in above selectable tab that jpeg is showing, and then save.
no problem, a wile ago i was in your place,couldnt get a pic resized werth a can a beens then some one on here pointed the resizer out for me so i keep trying to return the faver. its the only thing i like about Mic. win. XP
its amazing how simple and easy the resizer works, gota hand it to microsoft on this one they got it right
thanks for the help
Iramberson,
Here are some pics of the ol girl. I don't have regular welding service. I do alot of work for Concrete Redi mix plants and Concrete Block plants.I may be building equipment one day and installing a water system the next. I also do alot of trouble shooting. I buy and sell used equipment all over the the US and most of the time when I sell a plant I have to install it. I may be in Florida one week and Road Island the next week. Like I said I don't have a normal welding business. I have gotten so busy that I'm working 7 days a week15-18 hrs a day on average. If I'm lucky I get to work out of the home shop a couple days a week. At the home shop I build custom block molds and equipment for the Concrete Block Industry. I have so much work it's not funny. Anyway that's why I still use the pickup. It's loaded every day but it's usually loaded with different stuff everyday.
Thanks,
Bulldog
5 Passport Pluses
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
Star & stripe BWE Digital
2 star & stripe xlix's
5 Passport Pluses
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
Thanks Stick! Yea ya gotta love the Cummins. The white truck has over 300 thou and runs like it's new. I get the oil sampled every change (20,000)and it always comes back the same. Severity 0 .I bet the the thing will 5-600,000 easy.
Bulldog
5 Passport Pluses
2 MM 212's
MM 210
MM 251 MIA
MM 350 P w/Python
w/ tig runner
Trailblazer 302
12RC w/meters
Spectrum 1000
Spectrum 2050
2 Black BWEs
Joker BWE
I just checked out a website at Millerwelds.com/truck. This site has dimensional drawings for mounting purposes and has some cool accy's for machines mounted in tight spaces - like trucks.
I have a Trailblazer 302 mounted on a trailer but my toolbox blocks the oil filter and drain door. Miller appears to have addressed this with a remote oil filter and drain kit that I found on the web site. It's perfect for my trailer. I'll take some pics this weekend and post next week.
I've never been too sure why the ability to drain the oil from an engine ought nnot to be standard equipment. Lincoln, at least solved the issue
on their Vantage 400. Standard it comes with a petcock drain and a rubber hose extender with pre punched holes in the case on both sides and the radiator end. You can reach the petcock and change the filters through the generic engine access door on the right side. It is a sliding door so you don't need 'flip up' room. The only special access door is for the battery which is located behind a panel on the control panel end.
This is somewhat more thoughtful that our old Miller Big 40 which had
flip up side panels on both sides and important things behind both panels. Ourse was stuffed in a welder bay on a service truck where you could not open either flip panel. On that model even the connections for the welder leads was behind the flip panel Consequently the welder had to be removed from the truck even to hook up a welder lead or to do anything else to it except push the starter button and weld with it.
Miller Bobcat 225G
Lincoln Vantage 400
Lincoln Pro-Cut 80
one thing I like about the TB is how easy it is to remove the doors. They just slide up and out, so when blowing out the machine or doing maintenance, its dead easy to pop the doors off and put them out of the way, no fasteners to worry about. I imagine the only thing better would be doors that fully slide out of the way, as it would save about 5 seconds to open the door and pull it out. I'm not concerned. I'm still waiting for my Miller counterpart of the vantage 400. I think it might be a long wait
Hello everybody. There are some pretty nice rigs you guys have. Here is some pics of mine. Its a 3/4 ton ford with a service bodie that I built. I have a Trailblazer 302 with the HF 251d-1 and I have the RC12 wire feeder. I also have a MM175 for the smaller stuff. I am planing on getting the Spectrum 2050 plasma, hopefully soon.
Hey Trevwelder, that's a nice job. I'm using a 3/4-ton Ford also with a TB301G and everything else I need just in the bed right now, but am looking various options.
How heavy do you figure your bed and load is? What's your stopping distance?
Thank you MAC702. I weighed the intire truck on a scale that a rock crushing outfit had. It weighed just over 10,000 lbs. As for the stopping distance I don't know, but its not very good. I might do a little test with it just to see.
I had a trailer that I had everything on before and I did not like that to much. For the jobs that I was at for a long time is was nice, but for the quick or smaller ones it was more of a paine than it was worth. I hope to step up into a one ton, but that might be awhile.
Miller Trailblazer 302
Miller 12 RC wire feeder
Miller HF 251D-1
Miller 175 wire feed
