Um, how do you tack weld an aluminium T-weld? I always used those arrow magnet thingys for steel corner and T-welds but since aluminium is non-ferrious they can't be used. So how do you do it? My last joint in aluminium Tig welding is a T joint and I need to know how to pull it off so I don't ruin a bunch of aluminium.
Help with Tig and Aluminium
I find the best way to hold aluminium and other none ferrour metal at right angles is to get a steel angles brackets they are usually about 2" by 2" and get some really tiny clamps so that you clamp it all togather while you talk both ends and maybe a tack in the middle. Then remove the metal from this little jig and you will be ready to weld
I hope I have answered your question
I use a right angle plate (machinists angle bracket really), screwless vise, 1-2-3 blocks, and clamps to pinch the vertical plate to the horizontal, if on the bench of course. Works pretty well for me.
I have also used a cinderblock (CMU) for bigger parts. You are probably going to have to check the alignment after tacking anyways since it will pull.
Just some thoughts,
Joshua
If it's a small part, you can eyeball the angle, use a welding finger to hold it in place, tack it, then tweak it before you weld it solid.Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
