I need to know who has the maxstar 150 and if you have had any luck arc welding with it out of a 15 amp plug.
I get calls to go into drug companies, hospital surgical rooms etc. where they dont want nor will they let you run cables down their hall ways or through doors due to security issues.
I run 1/8 -6010 rod and 3/32 - 7018 rod at about 90 amps typically from my rig so I was wondering if I would have any success getting the maxstar to pump out 90 amps out of a standard 15 amp plug recepticle, I know they say you need a 20 amp plug however when is the last time you seen a 20 amp plug as a standard. thanks Portable Welder
