Chop Saw VS Dry Cut Saw
  • #46
    Originally posted by T_Bone
    Hi JT,
    I was looking at the blades that run in the $130 range and see Makita makes a couple blades for that saw. So you have the number of teeth or a stock number for just the blade?
    Another? Do you hog thru the cut? med pressure? or?
    Noise? Like a circular saw with a metal blade? or?
    I see that you've said you haven't cut any SS and on that page Carl sent us too, they make a blade for cutting SS, $240. Spendy but if it's like you say the carbon steel blade cuts, it'd be worth it.
    I get blades for right at $100 local.
    We do it just like the manual says, use enought pressure to drag the motor just a little, but not much. And if it makes sparks you're not pushing enough. So we push firmly.
    Loud skreeching noise, Kind of like a skill saw only more so.
    I don't have the foggiest on SS as of yet.
    JTMcC.
