Overhead Welding & BWE Helmet Question
  • Overhead Welding & BWE Helmet Question
    Reading through the owners manual for my new Miller Big Window Elite welding helmet I found this quote, "Do not weld in the overhead position while using this helmet."
    Why?
    Just courious.
    Thanks!
    Bill
    Bill
    Miller Dialarc HF
    Others will correct me if I`m wrong but I belive most non fiberglass welding helmets will say that.I`v got a Jackson Shadow that says basicly the same thing.
      Miller is just concerned and wants to keep the sparks from scooting down your shirt! i think Stick rod is correct.......although i haven't read the manual on my Optrel
        It's not that Miller is concerned about spatter going down your shirt lol. The exterior lenses are plastic, Overhead welding and plastic lenses just don't mix
          Miller recomends it to cover themselves in the event that someone melts through the clear with a big hot ball of metal and wrecks the lense, or worse themselves.
          That being said, I've done lot's of out of position, including some really awkward overheads, with Miller helmets and never had a problem. Your clear lenses won't last as long and the gasket tends to get burnt, but unless you do something extremely stupid the helmet should be fine.
          Owner of Burnt Beard Fabrication & Welding Ltd.
          BigBlue 500D
          Millermatic 211
          4' Box and Pan Break
          IR compressor
            The shell is plastic. No fiberglass in it to catch the hot slag. In the extreme overhead, when it is directly over your face, hot slag can burn through the shell and get to your face.
            I have burned up a shell already. That was when the meaning of this warning came through loud and clear.
            I use mine for all positions but OH is now done from the side where is it safe for my hood and my face.
            Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
              What good is a hood that can't be used for overhead??? Maybe for production line workers, but not any good for someone in the field..."I'm sorry boss, my hood won,t let me weld overhead"
                I use mine for everything. My overhead welds stay in the puddle
                Miller Trailblazer's ( 2 )...MillerBobcat 250...Millermatic 251's ( 2 )...Miller Syncrowave 200...Miller Syncrowave 180SD...Miller 12VS Suitcases ( 2 )... Hobart Hefty CC/CV Suitcases ( 2 )...Miller 30A Spool Guns ( 2 )...Miller WC 15A Control boxes ( 2 )...Thermo Dynamics Cutmaster 50 Plasma Cutters ( 2 )...Thermo Arc Hi Freq Units ( 2 )...Smith / Victor O/A Sets...DeWalt Power Tools...Craftsman / Snap On Hand Tools... Two Dodge Mobile Rigs
